Fuel Level System - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 30th, 12, 11:17 AM Thread Starter
Anthony
Fuel Level System
Hi Folks, Have seen several threads on this subject. Here's what I have. Fuel guage pegged at 3:00 position. I know that this corresponds typically to a poor ground. But when I ground the tan wire at the sending unit to the frame, the guage stays pegged. Does this mean that there is a disconnected tan wire somewhere further upstream towards to the firewall and instrument cluster? Has anyone run into this before and what was the outcome, before I start tracing wires. Thanks
surfcurran is offline
post #2 of 4 (permalink) Old Mar 30th, 12, 11:18 AM Thread Starter
Anthony
Re: Fuel Level System
Sorry, that's on a 68 standard convertible
post #3 of 4 (permalink) Old Mar 30th, 12, 03:12 PM
69-Pace's Avatar
Have you tested the wire from trunk to gauge for continuity?
It is a single connection trunk to gauge. You can test the gauge on the bench by using different ohm resistors on the tan lead to mimic the sender once you confirm the gauge is working. You can bench test the gauge and ground the tan lead to peg the gauge.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 4 (permalink) Old Apr 2nd, 12, 07:52 AM Thread Starter
Anthony
Thanks, I'll give that a go. Might also try and just ground it at the guage lead to rule out the guage itself. It has to be in that run somewhere between the instrument cluster and the sender.
