67 Camaro wiring diagram - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 30th, 12, 04:21 PM Thread Starter
Dean
islanddean's Avatar
Where could I find a Wiring diagram for a 67 Camaro? Specifically for the brake light harness. The existing harness disappears behind the trunk somewhere and I can't seem to locate it.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 7 (permalink) Old Mar 30th, 12, 07:36 PM
Roger
rogerh's Avatar
Re: 67 Camaro wiring diagram
The wiring diagram will not show you how the wires are routed through the car. The way the tail light harness is routed is down the left kick panel from the dash to a interior wire guard that runs along the inside of the rockers to the rear wheel well. Over the wheel well to the left side of the rear seat. If you look in the front, left side of your trunk you should see the wiring harness coming from the seat back. I noticed you have convert so it may be harder to find the harness in the front of the trunk. You may want to post this question in the convert section. I am sure someone can help.
Roger
rogerh is online now
post #3 of 7 (permalink) Old Mar 30th, 12, 09:32 PM
69-Pace's Avatar
Hey Dean - yeah it travels back on the drivers side, under the rear quarter trim and armrest under the top well over the wheel housing into the trunk. you can see is on the other side of the cocktail shaker. Whats your issue with it?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 7 (permalink) Old Mar 31st, 12, 03:49 PM Thread Starter
Dean
islanddean's Avatar
Thanks for the info guys. The wires on the harness are just old and very brittle...plus my back up lights do not come on. I did replace the bulbs, hse and neutral safety switch but that did not solve the issue so I'm guessing something wrong with the wires somewhere.
I do see the harness appears inside the driver side of the trunk just above the wheel well but am unable to trace it any further than that. What I'm trying to locate is where I will plug the new harness into the existing wires coming from the front.
MLK
post #5 of 7 (permalink) Old Mar 31st, 12, 05:19 PM
The body harness plug is behind or just above the drvr kick panel.
Check around the parking brake handle.
Reverse light switch, pink is power in from fuse panel, light green is out to lights.
post #6 of 7 (permalink) Old Mar 31st, 12, 05:23 PM Thread Starter
Dean
islanddean's Avatar
THANKS Everette...that is exactly what I was looking for.
MLK
post #7 of 7 (permalink) Old Apr 1st, 12, 06:11 AM
You're welcome.
