Sun super tach hook up? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 30th, 12, 05:26 PM Thread Starter
kevin
i just got a sun super 8K tack for a very good price.
my ? is how do you hook it up to a HEI distributor.
i see 3 wires on the back. one shows ign. switch. does that mean i have to pull the ignition switch?
one shows trigger, does that go to the tack feed on the distributor?
and the last shows ground , i guess i am not a complete idiot, i think i know where that one goes
thanks
flat tire is offline
post #2 of 4 (permalink) Old Mar 30th, 12, 05:51 PM
Jon
Re: sun super tack hook up?
Trigger plugs into distributor . Ground is ground and power off the fuse panel that goes on with key.
JR67RS is offline
post #3 of 4 (permalink) Old Mar 30th, 12, 05:53 PM
Red wire would go to IGN spade on the fuse panel.
Black would go to ground as you stated.
Green wire would go to TACH terminal on HEI next to BATT terminal.
You can crimp the light wire with IGN wire to have light come on with ignition power, if so equipped. Manf may have suppiled light wire with power wire inside the tach.
post #4 of 4 (permalink) Old Mar 31st, 12, 03:49 AM Thread Starter
kevin
thanks guys
