Can I wire electric fan relay like this? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 2nd, 12, 10:53 PM Thread Starter
Found this thread..
https://www.camaros.net/forums/showpo...2&postcount=13
Just like the picture using the switch also in the photo.
I would like control of the fan regardless of key position so I can run the fans for a bit with the key off if need be.
Then I'd also like them to be on automatically when the key is on and the car reaches a given temperature using the temp controller.
Thanks so much,
Donnie
68 Camaro - 540 HP AFR 412 CI, TH350 full manual, 3500 stall, 3.36 yukon gears/axles, 8.2" eaton posi, 17 inch Intro's. Jet black. Hotchkis sways, 3 in drop leafs/springs/bilsteins, G MOD, C5/4th gen brakes. 11.89 @ 119//2.01 60 ft
1968camaro123 is offline
post #2 of 5 (permalink) Old Apr 3rd, 12, 02:31 AM
Re: Can I wire electric fan relay like this?
Looks like it should work....but be aware that your relay may be numbered different. Follow the relay schematic.
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Apr 3rd, 12, 10:19 AM Thread Starter
Doug,
Thank you, I'll make sure that my relay matches that one before I wire it up
Thx again,
Donnie
post #4 of 5 (permalink) Old Apr 3rd, 12, 01:32 PM
Josh
The good controller kits come with everything to do exactly that, they have a solid state micro board with a relay (that is removable/replaceable) the override switch and a harness. I like the ones from summit. Easy to set up with a fully controllable temp setting from 150 to 250. The good one can run 2 fans at once, if you have a dual setup to run a low and then a high.
Grabbin2ndgear is offline
post #5 of 5 (permalink) Old Apr 14th, 12, 10:10 AM Thread Starter
I bought a flex a lite adjustable fan controller but it didn't come with any directions for how to wire a relay.
Just going to try and use that link along with the directions from the controller. I've done one before it's just been years and for some reason wiring/electrical is just not my forte.
Thanks again,
Donnie
