67 Horn Wiring Diagram - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 3rd, 12, 04:39 PM Thread Starter
Does anyone have a link to a diagram that shows the wiring for the horn on a 67? I am sure I have seen this in some post before, but after 1/2 hour of searching I can't find a link that still works. Thanks
TimPa is offline
post #2 of 6 (permalink) Old Apr 3rd, 12, 06:07 PM
69-Pace's Avatar
Re: 67 Horn Wiring Diagram
Do you have a copy of the 67 AIM? You can download full wiring diagrams from Jim's first gens dot com in the download section once you join.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Apr 3rd, 12, 07:00 PM
Roger
rogerh's Avatar
Check out this site. It has a lot of good info plus wiring diagrams.
Roger
http://www.rclabbe.com/rswiring/rswiring.pdf
rogerh is offline
post #4 of 6 (permalink) Old Apr 3rd, 12, 10:07 PM
cb
Send a message via Yahoo to flyingskibiker
From the horn relay:
Dark Green goes to horns.
Horns are grounded directly through their mounts.
Smaller Black wire that plugs in to voltage regulator runs to fuse block, inside to turn signal switch connector, up to horn button(s).
When button is pressed, the circuit is grounded through the column itself, across the rag joint, to the steering box, and to the chassis to complete the circuit.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #5 of 6 (permalink) Old Apr 4th, 12, 01:22 PM Thread Starter
And I did order a AIM
TimPa is offline
post #6 of 6 (permalink) Old Apr 4th, 12, 05:16 PM
cb
You'll find MANY uses for it!
