dash light / running light question - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 3rd, 12, 05:17 PM Thread Starter
Matt
I have a 68 Camaro standard coupe. A few years back I wired the car with a painless wiring kit. At the time everything worked fine but the car sat for a few years now I am having trouble getting my running lights and dash lights working. I have replaced the headlight switch and made sure the gauge cluster was grounded well. I know that the running lights and dash lights work cause when I switch the wires on the headlight switch they all work. The only terminal on the headlight switch that is working is the one for the park lights. So it has power at first pull but not when the headlights are on. On a 68 this terminal does not get used correct? I have tried several headlight switches and multiple brands. Any idea what could be going on? Thanks for the help. Matt
echelon3399 is offline
post #2 of 10 (permalink) Old Apr 3rd, 12, 06:03 PM
69-Pace's Avatar
Re: dash light / running light question
I'm not sure on 68's if the parking lights stay on when the headlights are on. I think that is the norm for 67's but not 69's where the parking lights stay on with the headlights.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 10 (permalink) Old Apr 3rd, 12, 06:07 PM
Parking lights and side markers stay ON with headlights on a '68 & '69.
You may have a '67 headlamp switch, no parking lights with headlights ON.
post #4 of 10 (permalink) Old Apr 3rd, 12, 10:20 PM
cb
Send a message via Yahoo to flyingskibiker
Sounds like you are getting power on the Orange wire but not the Red one??? But why doesn't the instrument lights work? Hmmm... Have you turned the switch knob all the way clockwise?
My '68 works this way:
First notch:
Orange (fused power) connects with Brown (running lights) and Dark Green (power to instrument lights rheostat)
Second notch (all the way out):
Sams as above plus Red (battery power) connects to Light Blue (headlight dimmer switch).
Rheostat is in-between the Orange and Dark Green wire terminals w/in the switch. When rotated fully and into the "notch", White is grounded to turn on courtesy lights.
There is an open socket in the plug/connector between the Dark Green and Brown if traveling in a circle around the plug. There is a second open socket between the Orange and Light Blue, as well.
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
Last edited by flyingskibiker; Apr 3rd, 12 at 10:44 PM. Reason: forgot an open socket!
flyingskibiker is offline
post #5 of 10 (permalink) Old Apr 4th, 12, 10:26 AM Thread Starter
Matt
Turning the knob doesn't do anything. I do have power to the red wire but have nothing to the orange wire. Could this be the problem? What could be causing the Orange wire to not get power?
post #6 of 10 (permalink) Old Apr 4th, 12, 02:18 PM Thread Starter
Matt
I figured it out. My horn fuse was bad. Thanks for the help. Matt
post #7 of 10 (permalink) Old Apr 4th, 12, 05:21 PM
cb
Wow. I didn't know the horn HAD a fuse... Maybe you mean the TAIL fuse???
post #8 of 10 (permalink) Old Apr 5th, 12, 10:40 AM Thread Starter
Matt
No it was the horn fuse. Like i said it is a painless wiring kit so maybe there was not one on the factory fuse panel.
post #9 of 10 (permalink) Old Apr 5th, 12, 02:32 PM
cb
Ah. OK. Thanks for the reply. I won't have to change any of my note, then. ;-)
post #10 of 10 (permalink) Old Mar 20th, 13, 02:12 PM
Robert
ROBS6T8's Avatar
for the search feature! I too was having issues with my dash lights and parking lights. Painless wiring also and came upon this thread. Checked the horn fuse and "bingo" blown! Who would of thunk it?
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
Tags
dash, gauge, headlight switch, running lights
