Courtesy light question - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 5th, 12, 01:19 PM Thread Starter
Gene
I am attempting to install LED lights under the dash of my 68. I read many of the post but must be missing something. My door jam switch on the driver side is a two wire. I fabricated brackets and installed sockets, planning for the bracket to ground to the dash and the hot to energize when the door opened. I am not getting anything. I have been unable to find the plug in mentioned in some of the post.
Thanks,
Gene68ss
gene68ss is offline
post #2 of 8 (permalink) Old Apr 5th, 12, 05:53 PM
Re: Courtesy light question
The door switches complete the circuit when the door is opened.
Power goes to the dome light, orange wire, through the bulb filament, and then exits out on the white wire to drvr door switch. DRVR door will have two white wires, one from the light socket and the other white wire to the pass door.
Switch open (door closed), no current flows, no light.
So, you would need to wire the new LED's the same way. Insulate the socket, maybe install it on a plastic bracket, or fasten the bracket made with a plstic/nylon screw with a plastic sheet/insulator between the bracket and dashboard, then wire the center contact to the orange wire and wire the socket case to the white wire.
post #3 of 8 (permalink) Old Apr 5th, 12, 06:09 PM
69-Pace's Avatar
Gene - take a look at Erics post. Search the same time period and find the post about the glove box needing to be reversed polarity, then look for the courtesy light bulb numbers and which ones didn't need reverse polarity then the socket had.
https://www.camaros.net/forums/showthread.php?t=204459
https://www.camaros.net/forums/showth...highlight=LED*
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 8 (permalink) Old Apr 5th, 12, 08:01 PM Thread Starter
Gene
Thank you very much for the response.I will get on that in the AM.
gene68ss
gene68ss is offline
post #5 of 8 (permalink) Old Apr 6th, 12, 06:41 AM
Eric
Just make sure the LED does not touch court. light bracket or your lights won't go out when you close your door. Like Everett said it has to be insulated from ground.
'69 Camaro, w/'67 L30 327 .030, L79 cam, 700DP, M20, 3.73 12 Bolt
L30 327 is offline
post #6 of 8 (permalink) Old Apr 6th, 12, 09:39 AM Thread Starter
Gene
Good advise, works great. Now I have no instrument panel lights, everything but the four that illimunate the panel works. Back to the drawing board.
Thanks,
gene68ss
gene68ss is offline
post #7 of 8 (permalink) Old Apr 6th, 12, 02:23 PM
Follow the gray wire for dash lights. Ground on cluster in place?
post #8 of 8 (permalink) Old Apr 9th, 12, 04:23 AM Thread Starter
Gene
Bingo, followed suggestions from sight and all is good now. I am 68 years old and was away from cars for over 40 years so I get a lot of good info from this sight. I am getting ready to post some 700R4 questions and comments, anyone reading this that is up to speed on that tranny, please look at my post.
Thanks,
gene68ss
gene68ss is offline
