GMPP mini starter wiring - Team Camaro Tech
post #1 of 1 (permalink) Old Apr 8th, 12, 12:05 PM Thread Starter
topher
69 383 tko 5sp's Avatar
I have the gmpp mini starter and have installed the AAW classic update
engine harness. The alt. is a one wire internally regulated unit. The mini
starter has two terminal posts that look like the same size and a spade
terminal off to the right side in the picture. There are no markings next to
these terminals but after checking continuity with volt meter, the upper
post and the spade terminal are on the same circuit. The AAW instructions
show the alt. wire and ign. wire going to same terminal on solenoid so I
have connected these(alt.blue fuse link-12v ign. brown fuse link) to upper
terminal. The purple has been connected to spade terminal. So that
leaves the bottom terminal for pos battery cable? Just want to be sure.
Thanks I appreciate any help
Name:	gmpp mini starter wiring 001.jpg
69 383 tko 5sp is offline
