Battery Cable Connections? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 9th, 12, 02:26 PM Thread Starter
I decided to replace the battery cables on my 69 Camaro SB and while measuring for size noticed some routing differences from the original AIMs manual. Currently the POS is routed directly to the starter which seems to be proper but the NEG is connected to the front exhaust header bolt (#2 cylinder).The manual indicates this should be connected to the alternator bracket. The small grounding wire from the NEG terminal is attached to fender as indicated in manual.
Additionally, I noticed another battery type cable connected to one of the thermostat housing bolts and running to a connection at the fender and rear hood mount bracket which I cannot locate this in the manual.
Anyone have any comments or ideas regarding this scenario as I am not aware of any issues this is causing.
jabeyers is offline
post #2 of 5 (permalink) Old Apr 9th, 12, 04:19 PM
Guess
HwyStarJoe's Avatar
Re: Battery Cable Connections?
I don't think there are any wires going to the thermostat housing or hood mount brackets. That's a strange one. Someone obviously added those. It almost seems like they're using them as grounds for the engine, which won't hurt, but there are much better ways to route them out of the way.
If you're going for authenticity, follow the AIM, but I attached my NEG to a lower water pump bolt to keep the wire out of the way. There's already the ALT harness up there so it would look cluttered even more.
HwyStarJoe is offline
post #3 of 5 (permalink) Old Apr 10th, 12, 04:05 PM Thread Starter
I suppose I could disconnect that cable and see if something stops working??
jabeyers is offline
post #4 of 5 (permalink) Old Apr 11th, 12, 12:41 PM Thread Starter
OK! I removed the questionable cable and could not find anything that stopped working. So unless there's some unforseen condition I'm not aware of, it goes to the spare parts bin.
jabeyers is offline
post #5 of 5 (permalink) Old Apr 12th, 12, 04:04 AM
Guess
HwyStarJoe's Avatar
