67 327 distributor - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 11th, 12, 09:43 AM Thread Starter
Cliff
67 327 distributor
hey guys
I am tearing down the 327 and planning a stock rebuild, except for the distributor. It's a 210 hp and I need to go with the HEI distributor. Is there one that yall would recommend? Go with vacuum advance or not? Any need for a flamethrower coil?
I am eyeing one at Ricks. Part # 720631.
thanks
blu7371fish is offline
post #2 of 6 (permalink) Old Apr 11th, 12, 11:47 AM
Re: 67 327 distributor
A pertronix kit will eliminate the points and look stock. The Ignitor 3 includes an integrated rev limiter. I've had no problems with mine for the past 7 or so years (Ignitor II and flamthrower coil). You ABSOLUTELY want the vacuum advance on a street motor.
Melrose RS is offline
post #3 of 6 (permalink) Old Apr 11th, 12, 12:39 PM Thread Starter
Cliff
thanks again Melrose RS!
post #4 of 6 (permalink) Old Apr 26th, 12, 12:48 PM
RICK
Also looking at pertronics. Can you replace the cap and rotor with stock gm parts or do you need to get that from pertronics. Looking to put a new distributor in mine but can't fit HEI type. Would like to use a distributor that you could use stock cap and rotor if you had to. Is there such an animal?
rick57 is offline
post #5 of 6 (permalink) Old Apr 26th, 12, 01:30 PM
You can still use the standard(non HEI) cap and rotor with a Pertronix module.
post #6 of 6 (permalink) Old Apr 26th, 12, 03:23 PM
RICK
Great, thanks for the responce. Going to Carlisle spring tomorrow, maybe pick one up there. Hope the weather is good.
rick57 is offline
