Wiring for windshield wiper motor? - Team Camaro Tech
post #1 of 4 (permalink) Old May 16th, 12, 05:11 PM Thread Starter
Matt
I am putting my car back together after 12 years and don't remember how the wiring went for the windshield wiper motor. I don't think it is a stock motor because the stock wiring has more connectors and terminals that the motor in the car. See photos below.
The last photo shows one way the wires could be installed. The one connector is zip tied back so I am thinking that it isn't needed. Maybe it is used for a wash pump if they had them originally.
Thanks for all the help.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #2 of 4 (permalink) Old May 17th, 12, 03:38 PM Thread Starter
Matt
Re: Wiring for windshield wiper motor?
Can anyone help me with this. I did some more research following the traces in the wiring diagram and see that the LBL, DBL, and B wires all go to the wiper switch. The 18Y wire goes to a fuse with nothing connected to the other side. I also saw in the manual that there is a washer motor the attaches to the wiper motor. But the motor in the photo only had 3 terminals not 4. I am thinking that is what the other connector is for but don't know for sure.
If no one knows I guess I can just hook it up and try it out. Hopefully it is idiot proof and I can't cause any damage.
Matt
MW67RS is offline
post #3 of 4 (permalink) Old May 17th, 12, 11:43 PM
Rocky
Ok Matt,
I just saw your post and went outside to check mine. I fitted a new wiper motor about 3 mnths ago. Looking at your pic with wires connected to me seems correct. The brown connector with LB and Yellow wire is for the washer pump, all the other wires connected in the pic are as mine.
My Wiper motor.
Hope this helps
What's a mid life crisis
67 SS
Hothead is offline
post #4 of 4 (permalink) Old May 18th, 12, 05:35 AM Thread Starter
Matt
Hothead, thanks for the photo. That is what I needed. Now I know for sure how to connect it.
Matt
MW67RS is offline
