67 factory tach not working w/photos of pcb - Team Camaro Tech
post #1 of 17 (permalink) Old May 27th, 12, 01:26 PM Thread Starter
BARTELL
Hey guys,
MSD 6AL, Blaster 2, and dist. Had OE tach plugged into box and got nothing. After reading posts, switched tach wire to neg coil post. Still nothing. Pulled out gauge cluster and took photo of PCB. Any connections missing? Anything?
BTELL67 is offline
post #2 of 17 (permalink) Old May 29th, 12, 04:18 PM Thread Starter
BARTELL
Re: 67 factory tach not working w/photos of pcb
Hooked up tach adapter today. Getting reading now, but seems low and slow. Oh well, it's a 45 yr old tach right??!! LOL.
BTELL67 is offline
post #3 of 17 (permalink) Old May 29th, 12, 04:52 PM
Farm Boy's Avatar
You can adjust the tachometer. There is a potentiometer on the tach for calibrating it. You can access it thorough a hole in the back of the tach housing. The hole on mine was covered with a small piece of paper. I suggest you use a small plastic screwdriver. You can get a plastic screwdriver at Radio Shack. Hook up a known good tach to your engine and dial in your tach to match it.
Farm Boy is offline
post #4 of 17 (permalink) Old May 29th, 12, 04:58 PM Thread Starter
BARTELL
Can I rent that gizmo you got to calibrate from an auotparts store?
BTELL67 is offline
post #5 of 17 (permalink) Old May 29th, 12, 04:59 PM Thread Starter
BARTELL
Cool Steve! I was wondering what the hole was for. Mine is not covered by the paper anyore.
BTELL67 is offline
post #6 of 17 (permalink) Old May 30th, 12, 08:52 AM
Michael
Doesn't the 6AL box have a tach feed from the box?
mahunt is offline
post #7 of 17 (permalink) Old Jun 4th, 12, 11:04 AM Thread Starter
BARTELL
Yes
BTELL67 is offline
post #8 of 17 (permalink) Old Jun 4th, 12, 11:05 AM Thread Starter
BARTELL
False alarm. Tach not working . Vibration is moving the needle. Aarrggghh!
BTELL67 is offline
post #9 of 17 (permalink) Old Jun 4th, 12, 05:24 PM
69-Pace's Avatar
You should use the Tach feed on the box with the filter in-line
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #10 of 17 (permalink) Old Jun 4th, 12, 09:27 PM Thread Starter
BARTELL
I'm using the Tach adapter into the box. Does the Tach filter do something different than the Tach adapter?
BTELL67 is offline
post #11 of 17 (permalink) Old Sep 25th, 12, 03:43 PM Thread Starter
BARTELL
UPDATE:
So I'm back to diagnosing the tach prob before I move on to an aftermarket.
I got correct voltage from 6AL box tach out put and tach adapter. MSD told me to check the printed circuit for the line on the pink 12v wire to make sure the 12v is making it from the harness to the tach. However, he said the parking brake uses the same circuit so if it is working then that means the circuit is good and the tach must be bad. The tach is doing nothing. It moves from 500 to 1000 rpm if your rev it enough but it seems to just be moving from vibration. Im gonna fiddle with that calibration screw and see if that does anything.
Any thoughts out there?
BTELL67 is offline
post #12 of 17 (permalink) Old Sep 25th, 12, 06:26 PM
69-Pace's Avatar
Originally Posted by BTELL67 View Post
UPDATE:
Do you have a engine analyzer? I'd double check that you are getting any signal from the box or coil over the feed line.
Then bench test the Tachometer by shunting power and ground then tach signal feed direct to the tach bypassing the PCB and harness wires.
If that works then the issue is in the PCB, if it doesn't work then the Tach needs work or replacing.
If it works then add the PCB and shunt power and tach feed to the right circuit ribbons on the PCB. If it still works then you have a possible power or ground issue with the unit or the connector to the PCB. If it didn't work just shunt power and grounds but run the same new lead to the tach feed from the coil. If that works then the feed line is bad in the harness. PITA process but it is the only way to isolate where the issue is.
69-Pace is offline
post #13 of 17 (permalink) Old Sep 25th, 12, 06:38 PM Thread Starter
BARTELL
Uh.hhhh. what?
Shunting?
BTELL67 is offline
post #14 of 17 (permalink) Old Sep 25th, 12, 06:46 PM
69-Pace's Avatar
Uh.hhhh. what?
Shunting?
To shunt is to bypass existing routes through existing harness or other connections.
69-Pace is offline
post #15 of 17 (permalink) Old Sep 25th, 12, 07:12 PM
Banned
Chet
Take tach to gage shop. Have them check it out. Probably dead. OE tachs and OER tachs don't get along well with MSD electronics. There is a thread on here about tach filters. Check it out. I sent my dead OER tach to redline gage and had modern electronics put in it for the cost of a new tach. Can't tell the difference.
154567 is offline
