1969 Camaro FUEL gauge problems - Team Camaro Tech
post #1 of 4 (permalink) Old May 28th, 12, 07:54 PM Thread Starter
JD
Hey guys.
So I have been trying to figure out this FUEL gauge.
We are changing our fuel gauge from the dash to the seated 4 gauges in the console. All the other gauges work ( oil, battery, and temp.)
Anways we changed out the wiring with the wiring kit and it keeps pegging all the way PAST full.
We think we have a good ground, but not sure what the heck it is.
Any ideas would be great.
Jake
jdepratti is offline
post #2 of 4 (permalink) Old May 28th, 12, 08:26 PM
Re: 1969 camaro FUEL gauge problems
Ground the point on the gauge that the tank sender connects to. Does it go to empty? If not, the gauge isn't working correctly. Are you sure you have the right wires on the right terminals?
go2fast is offline
post #3 of 4 (permalink) Old May 28th, 12, 08:30 PM Thread Starter
JD
yes everything is connected properly. we ohmed it out. we will try the tank sender... any other ideas?
post #4 of 4 (permalink) Old May 29th, 12, 05:19 AM
69-Pace's Avatar
Re: 1969 Camaro FUEL gauge problems
Follow the troubleshooter link:
https://www.camaros.net/forums/showpo...91&postcount=2
But also are you using original style reproductions made by Classic HQ? if so you must use the resistor on the rear of the gauge. If you are using OER reproduction the resistor is built in and needs no external resistor.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
