msd distributor - Team Camaro Tech
post #1 of 9 (permalink) Old May 31st, 12, 08:28 PM Thread Starter
jeff
jeff2425's Avatar
msd distributor
I am installing a msd magnetic pick up dist. in my 67 camaro. I got a new wire harness and it has the yellow and white wires tied together. the msd has the 6al control box and blaster coil. I think that I need to do away with the white resistence wire so I get the full 12 volts. any help or tips would be much appreciated thanks.
Name:	67 front view.jpg
ID:	28790   Click image for larger version
Name:	left side 406.jpg
67 RS SS 350 Bolero Red
black vinyl top
now under construction
after six years getting close.
jeff2425 is offline
post #2 of 9 (permalink) Old May 31st, 12, 08:31 PM
Steiner
Re: msd distributor
Supply the MSD box small red wire (control power, not the larger red one for the battery) via the spade connector marked IGN on your fuse block inside the car. Tape up or safety the ends of the other wires as they will not be used.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 9 (permalink) Old May 31st, 12, 08:42 PM Thread Starter
jeff
jeff2425's Avatar
Re: msd distributor
thanks steiner.
black vinyl top
jeff2425 is offline
post #4 of 9 (permalink) Old May 31st, 12, 08:51 PM
Steiner
Re: msd distributor
You bet.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 9 (permalink) Old May 31st, 12, 09:46 PM Thread Starter
jeff
jeff2425's Avatar
Re: msd distributor
so now for the dumd question. what gets wred to the actual coil since the brown wire goes to control box for tach.
black vinyl top
jeff2425 is offline
post #6 of 9 (permalink) Old May 31st, 12, 11:15 PM
Steiner
Re: msd distributor
Your coil connects to the 6AL box.
http://www.msdignition.com/uploadedF...structions.pdf
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 9 (permalink) Old Jun 1st, 12, 04:53 AM
Matt
Re: msd distributor
The orange and black wires coming out of the box go to the coil.The white wire does not get used.Bundle it up and tape off the exposed end so it can't contact any thing.The purple and green wires going into the plug together plug into the plug on the distributor.Heavy red wire goes to the positive side of the battery.The small red wire goes to an ignition hot.The heavy black wire goes a good ground.Your existing brown tack wire will connect to the tach out put port on the box.Good luck!
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #8 of 9 (permalink) Old Jun 1st, 12, 04:55 AM
Matt
Re: msd distributor
One more thing,the yellow and white wires coming out of the factory harness do not get used.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #9 of 9 (permalink) Old Jun 1st, 12, 04:25 PM Thread Starter
jeff
jeff2425's Avatar
Re: msd distributor
thanks everybody. I think I got it now.
black vinyl top
jeff2425 is offline
