Gauges - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 6th, 12, 01:35 PM Thread Starter
Barry J
Barry J's Avatar
Gauges
I would like to get some gauges to measure my battery, temp, and oil pressure. I was going to buy a gauge console with all three in, probably from Summit.
My problem is I don't even know if I have the wires to connect up to the gauges, or where I would connect them in my engine compartment.
I have a 67 Camaro, no power steering or power brakes.
Any suggestions or websites I can reference to hook everything up.
Barry
"Kids in backseats dont cause accidents.
..accidents in backseats cause kids!!"
Barry J is offline
post #2 of 2 (permalink) Old Jun 6th, 12, 02:13 PM
69-Pace's Avatar
Re: Gauges
Barry - If you are going aftermarket you will run leads to the gauges from the senders you will install in the block for temp and pressure. You may be able to retrofit the idiot light wiring but easier to run new clean runs.
If you are considering going factory OEM gauges then you can buy a conversion harness from American Auto Wire's Factory Fit product line and have plug and play conversion.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
