Testing help! - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 13th, 12, 08:18 AM Thread Starter
Testing help!
So I am looking at an 1968 Camaro AM/FM radio that is not tested. I am going to see the radio soon. How can i test it to see if it works? What ways are there to power it up without the car?
Its too hot to drive the camaro, no Ac!
(1968) Matching Numbers V8 327
ASH GOLD/BLACK TOP
Working on Radio/Speakers, Brakes.
Almost all original!
Camaro108 is offline
post #2 of 6 (permalink) Old Jun 13th, 12, 08:30 AM
Guess
HwyStarJoe's Avatar
Re: Testing help!
A cheap plug in 12V power supply from Radio Shack or similar. Or a car battery and some wire(s).
Get a couple alligator clips if it doesn't come with any. Bring your antenna also so you can see if it tunes.
HwyStarJoe is offline
post #3 of 6 (permalink) Old Jun 13th, 12, 08:31 AM
Bill
Calpantera's Avatar
Re: Testing help!
Ya just have a 12 volt power source like a battery or trandformer and connect the power and ground leads. Bring a speaker and connect it to the speaker leads one at a time.
Calpantera is offline
post #4 of 6 (permalink) Old Jun 13th, 12, 09:33 AM
Guess
HwyStarJoe's Avatar
Re: Testing help!
Oh yeah... a speaker would help too! LOL!!
post #5 of 6 (permalink) Old Jun 13th, 12, 07:35 PM
Re: Testing help!
Get some 1/4" female spade terminals from Radio Shack. Crimp or solder a few feet of wire to three of them. One is +12, one is ground and the negative side of the speaker, and the last is the positive side of the speaker. The terminals should be marked on the radio. Bring a few feet of wire for the antenna. If it does work, don't turn it up too loud with an 8 ohm speaker. They were made for 10 and those old transistors are easy to blow. Use a car battery or a good clean power supply (no battery chargers).
go2fast is offline
post #6 of 6 (permalink) Old Jun 14th, 12, 04:27 PM
cb
Send a message via Yahoo to flyingskibiker
Re: Testing help!
FYI, from the factory, the power is grounded through the chassis. Only the negative side of the speaker is attached to the radio... I just put the negative wire to the radio body itself. Probably not an issue. But thought I would pass it along. And yes, they used a 10 ohm speaker. Be careful there, too... Mine was still in the dash! ;-)
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
