69 tail lights - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 23rd, 12, 02:33 PM Thread Starter
Robin
69 tail lights
69 non-Rs Tail lights quit working. Fuse is good. Brake lights work. Hazard lights work. Turn signals work. Side markers work. Dash lights work. Inside the car with door closed I can rotate the headlight switch counterclockwise and interior lights will come on briefly and go off. Interior lights stay on with door opened. Bad switch?
1969 SS 396/375
11C Norwood
M21 3.73 12 bolt
rhcdmd is online now
post #2 of 6 (permalink) Old Jun 23rd, 12, 08:16 PM
Jeff
yellow69RS's Avatar
Re: 69 tail lights
Do the rear side marker lights work? I think the same wire powers the rear side markers and the tails. If the rear side markers are working I think the switch is good.
Jeff
yellow69RS is offline
post #3 of 6 (permalink) Old Jun 23rd, 12, 10:26 PM
Steps
Re: 69 tail lights
Bad ground in the tail light buld holder(s) or on the body...connecks just below the trunk catch.
Follow the no current back with a trouble light or multi meter.
Steptoe is offline
post #4 of 6 (permalink) Old Jun 23rd, 12, 10:34 PM Thread Starter
Robin
Re: 69 tail lights
Strange! When I posted earlier the rear side markers were working. Now they are out, too.
1969 SS 396/375
11C Norwood
M21 3.73 12 bolt
post #5 of 6 (permalink) Old Jun 24th, 12, 07:39 AM Thread Starter
Robin
Re: 69 tail lights
This is a brand new restoration. I cleaned the ground wire below the trunk latch. No result. I knew that the left (driver) side marker had been on earlier. I tested and it had power. Moved the bulb around and it came on. Both tail lights and right side marker still off. I took out the left tail light bulb holder and moved the bulb around. It came on along with the other tail light and right side marker. I guess these things are in series and if one is not connected, the ones on down the line don't get power. Guess I better clean all of the bulb holders.
I suppose problem solved. Thanks, guys! Now I can stay out after dark.
1969 SS 396/375
11C Norwood
M21 3.73 12 bolt
post #6 of 6 (permalink) Old Jun 24th, 12, 09:19 AM Thread Starter
Robin
Re: 69 tail lights
Correction: problem was in the wiring between left rear side marker and wire to left tail light. 43 year old wire splice had come undone. Fixed.
1969 SS 396/375
11C Norwood
M21 3.73 12 bolt
