Trunk Mounted Stereo - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 4th, 12, 06:19 AM Thread Starter
Matt
I am going to keep my original AM mono setup but would like to add a simple stereo in the trunk with a pigtail for my iPod. If anyone has any tips or pics of what they've done I'd appreciate it. Thanks
srq34231 is offline
post #2 of 7 (permalink) Old Jul 4th, 12, 07:06 AM
Brent
67Rally's Avatar
Re: Trunk Mounted Stereo
What are you looking for with a trunk mounted stereo? If you just want to run tunes off your iPod, you can connect it directly to an amp with the use of a line driver and skip the head unit. If you are using an iPhone, you can download an app like Pandora, and have radio functions as well.
Using the slider on an iPhone for volume control is kind of touchy. It would be much better to have a rotary knob of some kind to adjust it. The iPod would be easier for this function.
There's a rather long but informative sticky on pro-touring.com regarding this install: http://www.pro-touring.com/showthrea...ctly-to-an-amp
67Rally is offline
post #3 of 7 (permalink) Old Jul 4th, 12, 08:12 AM
Shane
I will be finishing up the install of a secret audio system today. I need to extend my antenna lead today. Ill add some pics later.
http://www.casmfg.com/Secretaudio.htm
I mounted the control unit in my center console. Unit has provisions for Ipod hookup, flashdrive use, and satellite input. It also has the CD and aux inputs. Outputs include the RCA outputs and a sub output.
Doing the 1 disc cd player since I listen to the radio 99% of the time. Will be adding a small sub later this week.
stea is offline
post #4 of 7 (permalink) Old Jul 4th, 12, 08:13 AM
69-Pace's Avatar
Well take a look at this one if your iPod or MP3 player or iPhone is going to be the major player and not CD or non-app based radio or scanner source. Easy to hide and use:
http://www.kicker.com/pxi502
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 7 (permalink) Old Jul 4th, 12, 08:36 AM Thread Starter
Matt
Thanks guys. Both good options. I'll check them out.
srq34231 is offline
post #6 of 7 (permalink) Old Jul 4th, 12, 03:01 PM
You can also install most any DIN mount head in the glove box, trunk, under the seat, etc and use an infrared remote extender (PAC IR-X) to run them. That's what I do in mine.
go2fast is offline
post #7 of 7 (permalink) Old Jul 4th, 12, 03:07 PM
This is what I'm thinking of doing. Pretty cheap online at around $200!
69 SS Silver Camro, LS3 efi, 4L60e with 2800 stall, mini tubed 12bolt 3.73, Ridetech front suspension ladder bar rear.
slugo10 is offline
