Help with Turn Signal Switch Wire Harness - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 12th, 12, 08:14 PM Thread Starter
Guillermo
I have a 68 steering column and an aftermarket or modern wireharness for my 67 camaro. The steering column has a curved male connection while the wireharness has a female straight connection. Is there an adapter that will connect the male curved from the steering column to the female straight connector of the wireharness? In other words I would need a female curved to male straight adapter. Any help would be appreciated.
gizcamaro is offline
post #2 of 6 (permalink) Old Jul 13th, 12, 03:11 AM
prostreet69camaro's Avatar
Re: Help with Turn Signal Switch Wire Harness
Yes they make one. You might try some of the parts suppliers like Ricks or Classic Industries.
prostreet69camaro is offline
post #3 of 6 (permalink) Old Jul 13th, 12, 10:52 AM Thread Starter
Guillermo
Thanks for the suggestion, but the only ones that I could find are the opposite of what I need. I need a female curved to male straight adpater.
post #4 of 6 (permalink) Old Jul 13th, 12, 11:55 AM
You might have to change the turn signal switch. Will this work?
http://www.classicindustries.com/cam...rts/g8065.html
http://www.rickscamaros.com/camaro-t...1967-1968.html
post #5 of 6 (permalink) Old Jul 13th, 12, 02:06 PM
69-Pace's Avatar
Also check with whoever manufactured the wiring harness for an adapter.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Jul 13th, 12, 02:52 PM Thread Starter
Guillermo
Thanks for the suggestions guys. I will look into the manufacture of the wiring harness.
