Headlights still flickering - Team Camaro Tech
post #1 of 18 (permalink) Old Jul 21st, 12, 11:38 AM Thread Starter
Ted
Hello again. I have been away and not able to tackle fully the issue of my flickering headlights. I have a 69 with a new Ididit column with the hi/lo dimmer in the turn signal arm. My headlights flicker either montarily or at a fast pace. They do not do it while the car is not running. They function perfect with the engine off. With the engine off I have tried to wiggle wires all over. Behind the headlights, ground wires and wires from the harness to the AAW modubox. I can not duplicate when it is not running.
When I start the car and turn the headlights on they can be fine. But once I hit the gas or letting off they have begun their sequence of spuractic flickering. I have a new battery, whole car AAW classic update wiring, new 140 amp alt, 6gauge alt sensing wiring to junction block, used heavier gauge wires elsewhere that I could to cut down on resistance and alt belt is tight. I have checked grounds and used star washers. Still no luck.
Here are the things elec that are not working properly in the car. Cigarette lighter does not work. Rear console light does not work. And the dome courtesy light does not come on when the light switch is rotated. But the switch is new.
The other thing that I noticed when cleaning the ground cable from the battery to the passenger side inner fender was. When I touched the ground to the body there is a little spark. Is that normal? I didn't think it should do that.
Car runs fine and none of the other lights be it dash, radio or anything work properly. I have read through 4 or 5 posts looking for suggestions to ring a bell with no luck so far.
tgifford5 is offline
post #2 of 18 (permalink) Old Jul 21st, 12, 12:01 PM
madmax87's Avatar
Re: Headlights still flickering
Ted, did you re-install the ground strap that goes around the light swith and then grounds to the dash. That is how the interior light works with the dial. It also connects to the wiper sw.
madmax87 is offline
post #3 of 18 (permalink) Old Jul 21st, 12, 12:13 PM
madmax87's Avatar
Here's a pic of the grouding strap that goes around the headlight sw and also connects to the wiper sw
madmax87 is offline
post #4 of 18 (permalink) Old Jul 21st, 12, 12:15 PM Thread Starter
Ted
Max I don't think I did. I'll check. Thanks
post #5 of 18 (permalink) Old Jul 21st, 12, 01:39 PM Thread Starter
Ted
Thanks Max. That was the problem for the dome light. No switch ground strap installed. Works now. Still flickering headlights
post #6 of 18 (permalink) Old Jul 29th, 12, 07:41 PM
madmax87's Avatar
I think I would take the alt down and have it tested. Sounds like when you accelerate and excite the alt to were it engages, the vol regulator is erratic. I take it thats its internally regulated.
madmax87 is offline
post #7 of 18 (permalink) Old Jul 30th, 12, 04:15 AM
69-Pace's Avatar
Yeah I agree with Dennis - sounds like Alternator and or Voltage Regulator issue
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 18 (permalink) Old Jul 30th, 12, 04:42 AM
Saprk from ground shoul dnot happen.
I would try a jumper wire from alt case to battery negative post to see if flicking goes away.
If it does, then you have an insulated alt to battery and should clean the bracketry of paint. Also, jumper body to engine block.
This action references all components to one level, puts all of them onto the same plane, so to speak.
If the flickering still does not go away, then as suggested, have alt tested.
post #9 of 18 (permalink) Old Jul 30th, 12, 07:41 AM
Darrell
I had a similar problem with my 68. I have Painless wiring harness. I had put in a new switch from NAPA. Turned out that switch was bad. I replaced it with a Delco and my problem went away. I knew it was the switch, I could put some pressure upward on the switch and they would work fine. Without pressure they would flash on and off usually while the car was moving and there was some vibration. Setting still they worked normally.
1968 Camaro, GM Performance ZZ4, TH350 W/Shift Kit, Sanderson Headers, MagnaFlow SS Exhaust, Vintage Air, Unisteer Rack, Dakota Digital, Ididit Column, Eaton Posi, 4 Wheel Disk Brakes, Custom Stripes
dsego is offline
post #10 of 18 (permalink) Old Jul 31st, 12, 05:54 PM Thread Starter
Ted
Guys I just tried this with no resolve. Jump wiring the alt case to batt neg. Flickering happened also when I had my 100 amp alt. The other suggestion regarding the Delco switch I have not tried yet. Even though it is a new switch. Could flickering be caused by any power wire under/in the dash that is hitting ground? I still neeed to resolve my rear console courtesy light and cigarette lighter not working.
post #11 of 18 (permalink) Old Jul 31st, 12, 06:24 PM
69-Pace's Avatar
Yup something grounding, or dead shorting might be responsible. Also check the fuse block connections and bulkhead connector or loose fit or shorted wires.
You could just hot wire "shunt" the headlights with the harness connection eliminating the switch, to see if it is the switch just use the right gauge wire shunts.
Cigarette lighter element or the socket is dead? Socket check ground of the socket to tray and dash assembly.
Courtesy light: Is there power at the stub connector (this is the dashboard side of the console harness) on the orange and white spades? Use a test lamp. If so then the issue is in the console side of the harness. If no power then trace from fuse block out.
Spark when negative cable is connected means something is drawing power. Either planned modern item like a clock or radio unit, or old - trunk light, glove-box light or short.
69-Pace is offline
post #12 of 18 (permalink) Old Jul 31st, 12, 07:14 PM
Kev
So disconnecting the low current ground causing a spark (a normal current path) is considered wrong?
Please. These are old cars and the ground paths are all rusted/corroded unless someone has cleaned them.
Many of the positive paths through switches, and connectors are resistive unless checked and fixed.
If the OP has a new AAW harness, the problem is in + connections or grounds. Since grounds are somewhat invisible, they are often ignored or forgotten.
Bad grounds.
Take an 8' 12G wire and solder alligator clips to each end. Connect one end to the headlight grounds (did you clean those?). Connect the other end to the battery.
Better? You're getting closer... Now try grounding to the rad support. No good?
67sc is offline
post #13 of 18 (permalink) Old Jul 31st, 12, 07:24 PM
Steiner
If the headlights are the only place the flicker is seen and not anywhere else I'd just do the headlight relay upgrade. Plug and play harnesses are only around $30 or so on ebay.
Spark when connecting the ground wire is normal especially if you have an aftermarket radio or other accessories with memory. Plus there is normal capacitance in an electrical system that will cause a quick draw when the battery circuit is completed.
'69 Camaro
500hp/538lbft
Steiner is offline
post #14 of 18 (permalink) Old Jul 31st, 12, 07:43 PM Thread Starter
Ted
I have already installed AAW headlight relay kit for the hi/lo beams. I havee redone some wiring to heavier gauge also. Like 6 ga. off the alt to the junction block for voltage sensing.
post #15 of 18 (permalink) Old Jul 31st, 12, 07:44 PM Thread Starter
Ted
Kev I have cleaned the grounds all the way around. I will try your suggestion.
