Gauge Light fuse - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 22nd, 12, 10:14 AM Thread Starter
Gauge Light fuse
1969 Camaro gauge light fuse continues to keep blowing went from 5 amp to 7.5 amp to 10 amp is something shorting out ?
1969 L89 is offline
post #2 of 4 (permalink) Old Jul 22nd, 12, 11:11 AM
Jeff
yellow69RS's Avatar
Re: Gauge Light fuse
Yes gray wire under dash is shorted. One common cause in the mid 80's was grounding an after market radio to this wire. I'm not sure why so many people thought gray was ground.
Jeff
yellow69RS is offline
post #3 of 4 (permalink) Old Jul 22nd, 12, 12:34 PM
prostreet69camaro's Avatar
Yes you have a short.
prostreet69camaro is offline
post #4 of 4 (permalink) Old Jul 22nd, 12, 01:05 PM
As suggested, if you added any new electronics, check wiring of new device.
Otherwise, either a gray wire is pinched to ground, or a bulb has a shorted filament internally within the bulb - seen this feat happen quite a few times.
Remove bulbs and test each one individually with an ohmmeter, meter should show some ohms, greater than 1 ohm.
