Volt. reg - Team Camaro Tech
post #1 of 16 (permalink) Old Aug 4th, 12, 10:56 AM Thread Starter
Barry J
Barry J's Avatar
Volt. reg
Last night after going to a cruise night, I parked my car in the driveway, and when I went to start it up to put it in the garage, the voltage regulator made a short vibration noise, right after the engine turned over.
Is this a sign that it is on its way out???
Barry
"Kids in backseats dont cause accidents.
..accidents in backseats cause kids!!"
Barry J is offline
post #2 of 16 (permalink) Old Aug 4th, 12, 11:17 AM
madmax87's Avatar
Re: Volt. reg
You sure it just wasn't your key buzzer? Do 67 Camaro's have that feature?
madmax87 is offline
post #3 of 16 (permalink) Old Aug 4th, 12, 11:37 AM Thread Starter
Barry J
Barry J's Avatar
Re: Volt. reg
Yeah..no....I put my head down next to the voltage regulator as my wife started the car, it was definitely coming from the regulator.
Barry J is offline
post #4 of 16 (permalink) Old Aug 4th, 12, 12:06 PM
DT
Donny
DT's Avatar
Re: Volt. reg
Old style VR?? They can make noise at times. Replace it with a solid state unit. They are much more reliable and/or trouble free. VR 715 is a common part#.
DT is offline
post #5 of 16 (permalink) Old Aug 4th, 12, 12:11 PM Thread Starter
Barry J
Barry J's Avatar
Re: Volt. reg
Solid state VR can be bought at an Autozone or CAP??? And are they much more expensive than the old style....This one I've got is only 1-2 years old
Barry J is offline
post #6 of 16 (permalink) Old Aug 4th, 12, 12:16 PM
DT
Donny
DT's Avatar
Re: Volt. reg
Yes the Solid State units are available at Autozone. They are inexpensive. 30.00 is probably high. Shop around. Ebay link: http://www.ebay.com/itm/WELLS-VR715-...sories&vxp=mtr
DT is offline
post #7 of 16 (permalink) Old Aug 4th, 12, 04:27 PM
69-Pace's Avatar
Re: Volt. reg
Wells/Artex Solid State VR $12.58 before the Team Camaro discount at rockauto.com
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 16 (permalink) Old Aug 4th, 12, 07:52 PM
DT
Donny
DT's Avatar
Re: Volt. reg
Don't want to hijack this thread but what is the ROCKAUTO discount code???
DT is offline
post #9 of 16 (permalink) Old Aug 5th, 12, 01:45 AM
69-Pace's Avatar
Re: Volt. reg
D12F683DD096 in the “How Did You Hear About Us?” line of your shopping cart. Then you should get private sales emails after that.
69-Pace is offline
post #10 of 16 (permalink) Old Aug 5th, 12, 05:58 AM
DT
Donny
DT's Avatar
Re: Volt. reg
Thanks!!!
DT is offline
post #11 of 16 (permalink) Old Aug 5th, 12, 06:40 AM
69-Pace's Avatar
Re: Volt. reg
If the code has expired, it was working long after the date it was to expire, you can always call and see if they will honor the Team Camaro discount over the phone with your user name here. As I mentioned, once your email is on the system you will get regular notices of discounts and special sales.
But I often find their day to day prices are far below the big box places, and I got an NOS part in original GM AC Delco box circa 1972 off the shelf as the regular replacement part price last fall.
69-Pace is offline
post #12 of 16 (permalink) Old Aug 10th, 12, 07:27 AM Thread Starter
Barry J
Barry J's Avatar
Re: Volt. reg
ok back to the subject.
Is there an easy way to check if my volt reg. is bad???
Barry
Barry J is offline
post #13 of 16 (permalink) Old Aug 10th, 12, 07:46 AM
click's Avatar
Re: Volt. reg
Barry, if you have never replaced it yet... go to most parts stores and get a Wells VR 715 and just replaced it. The new one is electronic, not points, and works much better anyway. Just around $12 too.
click is offline
post #14 of 16 (permalink) Old Aug 10th, 12, 10:19 AM
Randy
Re: Volt. reg
If it is bad your alternator will not be charging your battery. Check with a volt meter.
I agree about the electronic vreg. Put one one two months ago, looks like the original only slimmer. mounts exactly as the old style and just works. Just follow the directions and make sure it is grounded BEFORE you connect it up to anything. I also disconnected my battery until I had it all hooked up.
il_randyb is offline
post #15 of 16 (permalink) Old Aug 10th, 12, 10:32 AM
69-Pace's Avatar
Re: Volt. reg
If you want the Wells/Airtex Solid State unit to look just like the OEM unit, just remove your original full height cover, pop off the slim plastic cover of the Wells unit and mount your old cover. The Wells used to have the holes already drilled, but the last one I bought they were only punched to mark them I had to drill them out.
69-Pace is offline
