69 Camaro radio removal - Team Camaro Tech
post #1 of 11 (permalink) Old Aug 5th, 12, 07:14 PM Thread Starter
How do you remove the radio in a 69 Camaro? I'm trying to remove the gauge cluster but I'm having a hard time with it. Seems the radio needs to be detached from it first. I've removed the screw around the cluster and I've removed the brace from the radio. What am I missing?
makaveli is offline
post #2 of 11 (permalink) Old Aug 5th, 12, 07:52 PM
69-Pace's Avatar
Re: 69 Camaro radio removal
There is a metal strap holding the rear of the unit, then two washers on the knob shafts.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 11 (permalink) Old Aug 5th, 12, 08:01 PM Thread Starter
Thanks Brian. I must have missed the two washers
makaveli is offline
post #4 of 11 (permalink) Old Aug 5th, 12, 08:05 PM
If it is a factory style radio and it has not been modified, The only thing holding the radio in is the brace you mentioned and two nuts on the volume and tuning shafts. Just remove all 4 knobs and you should see the attaching nuts. You will need a deep socket. Dont remember which size! If it has been modified IE(it does not have the knobs) then you may need a special tool to release it.
69indyz11 is offline
post #5 of 11 (permalink) Old Aug 5th, 12, 08:41 PM Thread Starter
Thanks alot, Mark. I'll put your advice to work tomorrow!
makaveli is offline
post #6 of 11 (permalink) Old Dec 19th, 12, 12:43 PM
Anthony
I'm taking my factory radio out also. But am running into a problem with the tuner knob. It has something over the shaft, knob is removed, that is covering the nut. The nut is exposed on the volume side with no issues, but the tuner side has something over it. It is round with a small square hole on the top side. It seems I need to release it to get to the nut underneath? I can post a pic tomorrow if no one has any idea given my description. Thoughts? Thanks
domcenzo is offline
post #7 of 11 (permalink) Old Dec 19th, 12, 01:05 PM
It sounds like you have a round nut on one side. My Firebird has these. They are similar to the retainer for the headlight switch only smaller. There is a socket made especially for this but I made one by grinding down a cheap deep wall socket. I think it was a 7/16". Just grind two sides leaving two points opposite each other. There should be two slots in the retainer. I remember back in the day some makers used these round threaded nuts and some used the hex nuts.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #8 of 11 (permalink) Old Dec 19th, 12, 01:30 PM
Anthony
Thanks for the response. Actually, I do have them and removed the volume side nut with needle nose pliars inserted into the notches. The tuner side is not even exposed. It's like there is a round more thick piece covering the type of nut you are mentioning. I'll have to probably take a pic.
domcenzo is offline
post #9 of 11 (permalink) Old Dec 20th, 12, 07:44 AM
Anthony
Whatever this is on the tuner shaft is what I need to remove. What is this thing? And how is it removed? Thanks all.
domcenzo is offline
post #10 of 11 (permalink) Old Dec 20th, 12, 08:13 AM
Anthony
There are wires attached to it. It's almost like it's something having to do with the fader. Part # on it is 1376923 gm
domcenzo is offline
post #11 of 11 (permalink) Old Dec 20th, 12, 08:16 AM
Anthony
It's off. Just had to pull hard. Click image for larger version
domcenzo is offline
