Help. Am I screwed? Scared! - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 7th, 12, 10:45 AM Thread Starter
Shawn Hill
Ok, I was replacing the battery, it's in the trunk, on my 68 Camaro, when my wife asked if she could "help". I heard a snap and Smelled the dreaded burnt plastic. I yanked the cables off! Well, I don't think they taught "+" or "-" in Louisiana schools! If they did she was texting!
I found the burnt line and replaced. It was an "acc" line. I put key in the ignition and NOTHING !!
My question: Where do I start? I know the "+" line runs directly to the starter, do you think that the starter solenoid is fried? Would that be the best place to look? What should I look for?
Oh, yea! I JUST GOT EVERYTHING DIALED IN! I was dressing everything in.
shawnmhill is offline
post #2 of 13 (permalink) Old Aug 7th, 12, 10:46 AM
Randy
Re: Help. Am I screwed? Scared!
Fuses would be the best place to look first!
il_randyb is offline
post #3 of 13 (permalink) Old Aug 7th, 12, 10:54 AM
Michael Gekko
Indeed, check the fuses first.
Do the lights come on (dash or headlights/taillights)?
Eleanor's Nemesis is offline
post #4 of 13 (permalink) Old Aug 7th, 12, 10:58 AM
Michael Gekko
Just hooking up the cables wrong should not cause anything to happen.
post #5 of 13 (permalink) Old Aug 7th, 12, 11:50 AM Thread Starter
Shawn Hill
Fuses are good.
post #6 of 13 (permalink) Old Aug 7th, 12, 11:51 AM Thread Starter
Shawn Hill
Nothing comes on!
post #7 of 13 (permalink) Old Aug 7th, 12, 12:20 PM
Nick
Rarerat's Avatar
Check the little wire that runs from the pos side of the battery to the little junction block on the radiator support. My money is on that wire or the connection being bad. if you ever loose all power to the car that would be the first place to look.
Good luck..
Rarerat is offline
post #8 of 13 (permalink) Old Aug 7th, 12, 12:21 PM
If you still have the OE harnesses up front, you should check the main fusible links. Photo links in this thread: https://www.camaros.net/forums/showth...le+link+burned
Fusible links are there for a reason; to try to keep the car from burning down when something happens in the circuits. If they get to be 40 plus years old, they can start to fry on even fairly minor boo boos.
Eric
Eric Kammerer is offline
post #9 of 13 (permalink) Old Aug 7th, 12, 12:52 PM
Greg
There are just too many variables that could have happened.
You start with a voltmeter, a wiring diagram and start at the battery and go from there; i.e. term distribution post on passenger side rad support, next horn relay, next bulkhead connector on firewall. Follow the main buss.
Did you see smoke from the driver front headlight bucket area?
Check these and then get back.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #10 of 13 (permalink) Old Aug 7th, 12, 02:43 PM
Steps
Start with Nick and Erics uggestion above... if dont have a spare fusablke link use a bit of light weight wire ...which is basically what that fuseable link is....as a jumper see if things light up....turn ig on then touch the wire see if heats...
When this sort of thing happens (smell of burnt cable) the danger is in the looms, the break down of the wire insulation and burning the surrounding wires in the loom.. cusing shorts or even partal resistance between circuits.
Failing the above...follow thru with Gregs multi meter following circuits.
Steptoe is offline
post #11 of 13 (permalink) Old Aug 7th, 12, 06:27 PM
r_w
Robert
Tell her it's all your fault.
As above check the fusible links, if they are not there add them. Check all the wiring for melting or fusing together. Check all the wiring that moved the battery to the trunk in particular as it is not stock.
______________
Life is too short to drive cars that suck.
'67 Convertible
'68 Coupe
r_w is offline
post #12 of 13 (permalink) Old Aug 8th, 12, 12:56 PM Thread Starter
Shawn Hill
Good luck..
This was the issue! Got it! Back on the road! Told the wife she could help but only via text message!
post #13 of 13 (permalink) Old Aug 8th, 12, 01:06 PM
click's Avatar
another happy customer good job guys.
click is offline
