69 Camaro Turn Signals - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 31st, 12, 04:07 PM Thread Starter
Jason
My turn signals on my 69 camaro have quit working on both sides front and back. However if I turn on the Hazard Flashers all 4 seem to work. Does anybody know what this could be?
jbs_jbs2000 is offline
post #2 of 13 (permalink) Old Oct 31st, 12, 04:56 PM
Jeff
yellow69RS's Avatar
Re: 69 Camaro Turn Signals
Step on the brakes and see if they light up in the rear. Turn on the T/S and see if the front's light at all. If the rears light with the brakes the bulbs, wiring form the T/S switch and rear ground are good. There is a chance that the grounds for the front T/S are bad or the bubls. I assume you 've checked the flasher and the fuses.
Jeff
yellow69RS is offline
post #3 of 13 (permalink) Old Oct 31st, 12, 05:59 PM
Guess
HwyStarJoe's Avatar
Turn Signal Flasher
HwyStarJoe is offline
post #4 of 13 (permalink) Old Oct 31st, 12, 06:27 PM
Jeff
Originally Posted by HwyStarJoe View Post
Don't the hazards use the same flasher?
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline
post #5 of 13 (permalink) Old Oct 31st, 12, 08:18 PM Thread Starter
Jason
I checked Fuses and all are good. Brake Lights come on when pressing brakes and all lights come on when I turn on the lights. The signals only do not work when I turn them on. Niether the front or back will flash when turned on but if I turn on hazards all signals flash
post #6 of 13 (permalink) Old Oct 31st, 12, 08:24 PM
69-Pace's Avatar
Nope. Turn Signal flasher is under the dash by the radio, Hazards flasher is on the fuse panel.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 13 (permalink) Old Oct 31st, 12, 08:56 PM Thread Starter
Jason
Does the turn signal flasher look just like the hazard flasher?
post #8 of 13 (permalink) Old Oct 31st, 12, 09:01 PM
Jeff
No wonder replacing the one on the fuse panel didn't help the turn signals.
Build thread:
post #9 of 13 (permalink) Old Nov 1st, 12, 06:52 AM
69-Pace's Avatar
From the factory yes but over the years one may have been replaced with a Heavy Duty or square unit while the other remained factory light duty round.
69-Pace is offline
post #10 of 13 (permalink) Old Nov 1st, 12, 06:54 AM
69-Pace's Avatar
Yes been there done that.
69-Pace is offline
post #11 of 13 (permalink) Old Nov 1st, 12, 07:30 AM
Guess
HwyStarJoe's Avatar
Yeah, the turn signal flasher is up under the dash right by the radio. It's pressed between 'tongs' holding it to a dash brace.
post #12 of 13 (permalink) Old Nov 1st, 12, 05:53 PM
r_w
Robert
Turn signal flasher. You can swap the hazard one with the turn one to see if the problem follows, they should work the same. Originals were thermals (tin cans).
______________
Life is too short to drive cars that suck.
'67 Convertible
'68 Coupe
r_w is offline
post #13 of 13 (permalink) Old Nov 2nd, 12, 01:36 AM
steve
check the fuse holder for corrosion. I had that same problem on a car several years ago. Power went through the fuse , but not into the circuit. cleaning the clips that hold the fuse solved the problem.
grampstoyz is offline
