67 RS oil gauge - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 8th, 12, 06:20 PM Thread Starter
67 RS oil gauge
Not quite an electrical issue so I hope this is the right forum. My oil gauge line for the console gauge appears to have air in it. I can see light and dark areas in the line under the dash. The pressure reading changes from almost nothing to about a third after starting and moves to just under half with some RPMs so the gauge seems to work. Do I need to bleed the line? Is the air indicating there is a leak? How hard is it to replace the line and does the gauge need some kind of calibrating after that?
trland is offline
post #2 of 4 (permalink) Old Nov 8th, 12, 06:59 PM
Steiner
Re: 67 RS oil gauge
Completely normal. No worries.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 4 (permalink) Old Nov 8th, 12, 07:46 PM
keith
X-77 keith's Avatar
Re: 67 RS oil gauge
Like Steiner stated normal . You can bleed the line, but it will be back the way it is now. If it is not leaking it is fine.
X-77 keith is online now
post #4 of 4 (permalink) Old Nov 8th, 12, 07:52 PM Thread Starter
Re: 67 RS oil gauge
Thanks. I wasn't looking forward to dismantling the gauges or replacing the line if I didn't have to.
trland is offline
