Project 67RS Camaro - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 18th, 12, 10:49 PM Thread Starter
Miles
Project 67RS Camaro
Hi Camaro fans !
I have a 1967 RS Camaro . The wiring is all hack up . So with that said I have a hei distributor and a one wire alternator . Should I go to the junk yard to splice a wiring harness togather with my old one or buy a ebay wiring harness ? Cash in short so I'm not looking to spend alot .
67rs_camaro is offline
post #2 of 12 (permalink) Old Nov 18th, 12, 10:51 PM Thread Starter
Miles
Re: Project 67RS Camaro
post #3 of 12 (permalink) Old Nov 19th, 12, 08:21 AM
Michael
No, don't continue to hack your harness.
Get a new one that incorporates your HEI and one wire.
mahunt is offline
post #4 of 12 (permalink) Old Nov 19th, 12, 08:51 PM Thread Starter
Miles
Where and how much ?
post #5 of 12 (permalink) Old Nov 20th, 12, 07:01 AM
Is it a real 67 RS or a partial conversion? What's the TT read? You have 68 fenders and a standard valance. Where are the reverse lights located? Decipher TT here: http://www.camaros.org/numbers.shtml#CowlTag
Sauron67MM is offline
post #6 of 12 (permalink) Old Nov 20th, 12, 07:14 AM
Michael
Go online and check out the usual Camaro suppliers, or give 'em a call.
mahunt is offline
post #7 of 12 (permalink) Old Nov 21st, 12, 01:53 PM Thread Starter
Miles
It is a real RS . Right now it is a parts car and needs alot of the right parts .
post #8 of 12 (permalink) Old Nov 21st, 12, 02:06 PM Thread Starter
Miles
Cowl Tag Decode:
Build Date- O5 -- May
Model Year -- ST 67 -- 1967
Series and Interior Style Code - 12437 - Sport Coupe, standard interior
Build Site -- LOS - Los Angles
Interior Trim - 760 - Black standard buckets
Lower Body Color -- L-L - Tahoe Turquoise
Options W - tinted windshield
2MG -- M, (LOS - TH400), G, center console, S - rear antenna ("2" appears as a trim tag location identifier on Camaros with one of the above options but is not an option code itself)
3L - L - RPO Z22, Rally Sport Equipment ("3" appears as a trim tag location identifier on Camaros with one of the above options but is not an option code itself.)
post #9 of 12 (permalink) Old Nov 21st, 12, 02:08 PM Thread Starter
Miles
This is the ad for the car when I bought it. It is only a RS car . No rust .
1967 Camaro RS/SS -- This is a project Chevolet muscle car that will require restoration. I have lowerewd the price due to the fact that I found out the engine is not orginal and therfore it would cost about $ 600 to replace. This car is all original and it has not been on the road since 1978. There is no rust, yes this is an original California car, and the motor is a small block and the transmission is a turbo 400 Auto-matic. This is not a power-glide trans car!! The car was purchased from the original owner and stored since 1978 in a covered garage. There are three areas that will need additional repair and the left front fender has some areas that are suspect. Both rear quarter panels need to be repaired and there is a small section above the driver's door that will need repair (this is a small dent). The left front fender is not original to the vehicle. You can see from the pictures that there is no rust on this vehicle and the under portion also confirms this fact. All of the glass is in great shape with exception of the front windshield. All of the trim pieces are in place except for a short strip above the driver's door. This car has power steering and the rear end is a 10 bolt posi-traction unit and is original to the vehicle. The seats are bucket seats with the headrest but the headrest attachment has departed the fix. The Rally rims go with the car. There is a light coat of primer applied to protect this car while I was waiting to restore it but I am in the middle of two projects and cannot see me getting to this one for about another four -- five years. I believe that this is a numbers correct vehicle but I am not as knowledgeable on Chevy's to be able to confirm that fact.
Note (Los Angles Camaros that were manufactured prior to September were not marked with the SS option on the Cowl Tag, so if the cowl tag were marked at this point you might suspect a forgery)
This vehicle is being sold as is and no warranty is included. The buyer is responsible for shipping and handling but we will assist in any way that is reasonable to help you get this car to you. The buyer will be expected to provide a $ 1,000.00 cash deposit (non-refundable) within 48 hours. $ 7,0000.00
post #10 of 12 (permalink) Old Dec 10th, 12, 12:01 AM Thread Starter
Miles
Now my fuse box is rusty.... Can I save it ??? Or do I have to buy ???
post #11 of 12 (permalink) Old Dec 10th, 12, 03:34 PM
jared
I have a 67 rs/ss and It had all the same problems ,but the fuse box was ok,but did have a little rust that a dremel drill took care of on the fuse holders. The fire wall was a real mess, wires missing and wires added, So I bought a AAW wiring harness for the motor and lighting . You can't go wrong with them.They do cost a little bit more but they are a plug and play set up.Everything hooks right up and looks factory !!! Some of the ebay items are cheap and also junk. I'd bit the bullet and buy a AAW harness , you'll be glad later that you did
jcfcamaro is offline
post #12 of 12 (permalink) Old Dec 11th, 12, 07:21 AM
Jason
blue89bird's Avatar
Save your money and pick up an AAW classic update harness for your car. You will be worlds ahead and never worry about whether your car is going to catch fire. Wiring is something that should never be cheaped out on.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
