Headlamp Plug Pigtail - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 24th, 12, 06:17 AM Thread Starter
Matt
I can't guess why, but the plug for my right headlamp has been spliced in. The connection is poor so I need to cut it out, re-solder, insulate, etc. Problem is, the wires are a bit to short to work on. I can cut and add another piece of wire, but that is even sloppier. Does anyone know where I can get just a pigtail for a headlamp so I can simply splice in a new (or used) one? Thanks
srq34231 is offline
post #2 of 7 (permalink) Old Nov 24th, 12, 06:37 AM
Vega$69's Avatar
Re: Headlamp Plug Pigtail
Pull the plug off the headlight. Remove the terminals and add new ones with longer wires. Then you can make only one connection for each wire.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 7 (permalink) Old Nov 24th, 12, 06:50 AM Thread Starter
Matt
I thought about that but figured it would be harder to find a few individual terminals that fit. Thanks
srq34231 is offline
post #4 of 7 (permalink) Old Nov 24th, 12, 09:44 AM
69-Pace's Avatar
LectricLimited has terminal, housings and a ton of other repair parts.
http://www.lectriclimited.com/mainpage.htm
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 7 (permalink) Old Nov 24th, 12, 10:02 AM
kevin
SPEEDWAY
Price:
$6.99
PR
In Stock
View Larger
Item #:
91064601
Select QTY:
Read all 5 reviews
Write a review
Photos
Click image to enlarge
Info
Specs
Reviews
Questions / Answers
Three prong terminal with wire leads for 2 or 3 prong headlights. Also works for turn signal flasher.
Wiring
flat tire is offline
post #6 of 7 (permalink) Old Nov 30th, 12, 03:25 PM
Bobby
The terminals are Packard 59. You can get them and some color coded wire and put the splice up further in the loom. Just make sure you get the correct terminals, I think the lefts are double and the rights are single.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #7 of 7 (permalink) Old Nov 30th, 12, 06:02 PM
Daryl
1968RallySport's Avatar
Any Napa store will have the repair pigtail you are looking for.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
