Holley Electric Choke,..where to wire from - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 26th, 12, 11:05 AM Thread Starter
Wes
To what are you wiring the positive wire from the Holley electric choke? The directions say to not wire it to the "+" side of the coil.
I guess I could wire it to the "IGN" port at the fuse box or maybe there's a better way,..maybe at the alternator or somewhere.
This wire is only to be hot when engine is running.
Any advice?
Straight-line-69 is offline
post #2 of 11 (permalink) Old Nov 26th, 12, 11:56 AM
Guess
HwyStarJoe's Avatar
Re: Holley Electric Choke,..where to wire from
I'm not using my heater (no heater core installed) so I tapped the power for my choke to the orange wire on the firewall. I just keep the fan control ON all the time.
HwyStarJoe is offline
post #3 of 11 (permalink) Old Nov 26th, 12, 12:12 PM
topher
69 383 tko 5sp's Avatar
I was told you could use the wiper feed so thats what I tapped into for mine.
69 plain jane 383,TKO 600, 10 bolt mono 3.08 w/caltracs, TT2's 17"x9.5 rear 17'x7 fr. Goodyear F1 275/40/zr17,215/45/zr17.QA1 coil over. Speed tech uca/lca. March ultra serp.
69 383 tko 5sp is offline
post #4 of 11 (permalink) Old Nov 26th, 12, 02:59 PM
DT
Donny
DT's Avatar
X2 very simple this way.
DT is offline
post #5 of 11 (permalink) Old Nov 26th, 12, 03:47 PM
The electric choke should be wired to a switched, positive wire, that has power when the key is on and the engine is running. You have to use a switched wire or your choke will have power 24/7. The choke will not close and you will drain your battery.
As you mentioned, you might have to run a switched wire from your fuse block.
Good luck
MJK-4 is offline
post #6 of 11 (permalink) Old Nov 26th, 12, 03:57 PM Thread Starter
Wes
Sounds like a plan. Which of the three wires to the wiper motor is to be used? (I guess I could test with my volt-meter,..lazy).
Thanks!
post #7 of 11 (permalink) Old Nov 26th, 12, 04:40 PM
Vega$69's Avatar
Battery side of coil is the easiest
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 11 (permalink) Old Nov 26th, 12, 04:49 PM
DT
Donny
DT's Avatar
I believe the wire is black with a yellow stripe (Top terminal) on wiper motor.
DT is offline
post #9 of 11 (permalink) Old Nov 26th, 12, 05:05 PM
Correct,
Do not use coil + terminal as voltage will be reduced because of the resistive wire and choke heater will never get warm/hot enough to open.
post #10 of 11 (permalink) Old Nov 26th, 12, 05:27 PM
Vega$69's Avatar
Originally Posted by Everett#2390 View Post
Correct,
Sorry I was thinking of pointless Dizzy type without ballast resisters or resister wiring.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #11 of 11 (permalink) Old Nov 26th, 12, 05:32 PM
Keep in mind wiper has power when ign switch set to accessory....
So if you sit listening to the stereo, you will be chokeless, dechoked, unchoked and cachocked.
Moved mine to the coil wire, but I do not have resistive wire.
stouchton is offline
