Limit switch harness routing - Team Camaro Tech
post #1 of 15 (permalink) Old Dec 9th, 12, 10:58 AM Thread Starter
Jason
blue89bird's Avatar
Can anybody take a picture or describe how the limit switch harness for the switches on the core support are run?
I think I've got the PS run properly, but the DS seems to be short, so I'm sure I've got something run incorrectly.
Thanks,
Jason
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #2 of 15 (permalink) Old Dec 9th, 12, 04:40 PM
Roger
rogerh's Avatar
Re: Limit switch harness routing
I hope this helps. The blue wires go in to the bottom and the green on the RT and the purple on the LT go in to the top.
Roger
rogerh is offline
post #3 of 15 (permalink) Old Dec 10th, 12, 05:25 AM Thread Starter
Jason
blue89bird's Avatar
Thanks Roger! Back to the garage I go after work today.
Jason
post #4 of 15 (permalink) Old Dec 10th, 12, 03:21 PM
jared
X2 , That's how I ran mine .
jcfcamaro is offline
post #5 of 15 (permalink) Old Dec 12th, 12, 12:42 PM Thread Starter
Jason
blue89bird's Avatar
still can't get the DS wiring to the switches in the capsule to go.
If you look at this, you can see on the top right the wiring, it has basically no slack.
This is the harness behind the core support where it runs:
Do you know where this ground wire goes?
The core support wiring fits just fine:
Jason
post #6 of 15 (permalink) Old Dec 12th, 12, 01:59 PM
Roger
rogerh's Avatar
Does these brown wires come right from the relays? Could you have the relays connected wrong? Or maybe the relay board was mounted too fare back on the fender.
I don't have any slack in those brown wires either but it does connect. Look at this picture and you can just see the wires going behind the headlight socket. This was before the restoration and you can hardly tell the colors of the wires.
Roger
Name:	LT OB SW.jpg
rogerh is offline
post #7 of 15 (permalink) Old Dec 12th, 12, 02:12 PM
Roger
rogerh's Avatar
This is a picture of the mounting bolts of the relay board. I can see if someone mounted the board and used that prepunched hole to the rear of the bolts then the brown wire could be too short.
Roger
rogerh is offline
post #8 of 15 (permalink) Old Dec 15th, 12, 06:55 PM Thread Starter
Jason
blue89bird's Avatar
Roger does your wiring harness lay on top of the inner fender, or go behind the fender on top of the inner fender?
Jason
post #9 of 15 (permalink) Old Dec 16th, 12, 09:11 PM
Roger
rogerh's Avatar
It is ran inside of the fender. You can't see it in the engine compartment at all.
Roger
rogerh is offline
post #10 of 15 (permalink) Old Dec 17th, 12, 04:55 AM Thread Starter
Jason
blue89bird's Avatar
Roger
Well there we go! What a pain in the rear but at least I know what's going on now.
Jason
post #11 of 15 (permalink) Old Dec 17th, 12, 03:51 PM Thread Starter
Jason
blue89bird's Avatar
Well I pulled out my headlight buckets, undid the entire harness and just re-ran it behind the fender. I ran out of time before I had to start making dinner but it sure looks like I got the inch or so of slack I needed!!!
Thanks so much Roger. If I'm ever in the area, I owe you a beer!
Jason
post #12 of 15 (permalink) Old Dec 17th, 12, 04:23 PM
Roger
rogerh's Avatar
Glad I was able to help. You can keep your beer if you post some pics of the finished project.
Roger
rogerh is offline
post #13 of 15 (permalink) Old Dec 18th, 12, 10:25 AM Thread Starter
Jason
blue89bird's Avatar
It actually still looks a little short!
I'm going to try and pull on it some and see if I can pursued it into place but if that doesn't do it I'm all out of ideas except for maybe cutting off the end and soldering on an extension.
Jason
post #14 of 15 (permalink) Old Dec 19th, 12, 03:12 PM Thread Starter
Jason
blue89bird's Avatar
I got it!
Of course I've got some sort of bad ground because the headlights open up but don't close and the lights don't actually go on.
Jason
post #15 of 15 (permalink) Old Dec 19th, 12, 04:59 PM Thread Starter
Jason
blue89bird's Avatar
Woot! I had my dimmer switch disconnected, headlights open and close and turn on!!!!
Driver side headlight is dim, and my parking lamps, turn signals and tail lights light up though with the battery plugged in though, so I need to track down a ground issue.
Jason
