Troubleshooting horn - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 20th, 12, 02:54 PM Thread Starter
Jason
blue89bird's Avatar
Horn doesn't work, hasn't since I've owned the car. Brand new horn relay and headlight harness.
If I power the horns directly they work fine.
If I jump the horn wire on the relay to the big black or red wires on it, the horns work.
If I ground the buzzer wire, it buzzes, if I ground the relay wire, it clicks.
Any ideas?
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #2 of 10 (permalink) Old Dec 20th, 12, 03:21 PM
Re: Troubleshooting horn
The black wire from the steering column, the horn button, provides a ground energizing the horn relay.
Testing the relay would require a jumper from ground to the black wire terminal.
Relay energizes horn works, bad wire or ground spot under the horn button.
Black wire, between the gray wire and dark blue wire. also goes through the steering column connector and through firewall connector.
post #3 of 10 (permalink) Old Dec 20th, 12, 03:23 PM
Broken rag joint wire/strap.
Sauron67MM is offline
post #4 of 10 (permalink) Old Dec 20th, 12, 03:35 PM Thread Starter
Jason
blue89bird's Avatar
Scott,
Can you clarify? It's a new rag joint as I converted to power steering but I don't remember there being a ground wire or anything on it.
Jason
post #5 of 10 (permalink) Old Dec 20th, 12, 03:40 PM
The strap(s) with the bolts transfer the current path across the rag joint.
http://www.rickscamaros.com/camaro-s...1967-1969.html
post #6 of 10 (permalink) Old Dec 20th, 12, 03:43 PM Thread Starter
Jason
blue89bird's Avatar
Thanks I'll take a look but I don't think that's it since it's brand new.
Jason
post #7 of 10 (permalink) Old Dec 20th, 12, 04:40 PM
69-Pace's Avatar
x2
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 10 (permalink) Old Dec 20th, 12, 04:48 PM Thread Starter
Jason
blue89bird's Avatar
Just to clarify With my steering wheel removed can i just press the little brass button down with my finger and make it honk? If not, whats the proper way to test?
Jason
post #9 of 10 (permalink) Old Dec 20th, 12, 06:04 PM Thread Starter
Jason
blue89bird's Avatar
well that was easy. I thought the switch behind the steering wheel was just that, a switch that went on and off. I didn't realize the power ran through it and completed the circuit when you press the horn button. I jumped a wire from the button to ground and the horn works.
Jason
post #10 of 10 (permalink) Old Dec 20th, 12, 06:31 PM
Cool! Yes, power does run through the black wire.
