Rs headloght doors won't open after battery spark - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 21st, 12, 09:12 PM Thread Starter
BARTELL
So I was reconnecting my battery and accidentally touched the neg and pos with the wrench and sparked it. Now headlight doors will close, but they won't open when headlights turned on. If I push them open manually, they will close when I turn the headlights off. Maybe shorted out a relay?
BTELL67 is offline
post #2 of 5 (permalink) Old Dec 22nd, 12, 06:28 AM
69-Pace's Avatar
Re: Rs headloght doors won't open after battery spark
Are they factory or aftermarket? Could be either the relay or the controller shorted out. Or diodes may have fried.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 5 (permalink) Old Dec 22nd, 12, 08:31 AM
There is a tread right below yours where we have been discussing a very similar problem on original 67 systems.
https://www.camaros.net/forums/showthread.php?t=205750
The easiest starting point (I think) would be to unplug your front headlights & put a little “jumper wire” in the light green wires to the tan wires, black is for ground.
Then try pulling the light switch & see if it corrects the problem, if not, check the under dash diode.
If the problem is NOT solved by one of the 2 things listed above, you will just have to keep doing searches on this site & try to trouble shoot &/or eliminate things as either good or bad in your system.
327!275hp!Convt! is offline
post #4 of 5 (permalink) Old Dec 22nd, 12, 08:57 AM
Jason
blue89bird's Avatar
The open circuit is controlled by the light switch, the closing circuit by the ignition switch.
First thing I'd do is check to see if the diode is ok. If it is, I'd pull the relay board down and test them. All 3 are the same same you may be able to swap them and see if you can then make them open instead of close to determine if one is bad.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #5 of 5 (permalink) Old Dec 22nd, 12, 11:49 AM Thread Starter
BARTELL
Thanks guys. They are aftermarket. I will start with the Relays.
BTELL67 is offline
