Electrical help. - Team Camaro Tech
post #1 of 24 (permalink) Old Dec 23rd, 12, 05:37 PM Thread Starter
Wayne
Electrical help.
I just started here. Dont know how to start a new post.
But... This is why I signed up...
1967 Camaro,
Dash lights went out, then brake, running, and blinkers went soon after. Fuses all got replaced just to be sure, still nothing. Found a Yellow wire pinched between steering column and dash. "cant find where the wire is supposed to be connected." After reliving the pinched wire still nothing. I then replaced the headlight switch and still nothing. I then proceeded to jump a wire from the "red" hot wire to the running light lead on the harness and got my lights back. Did the same with brakes and got power there also. I then changed out the switch with three other light switches yet still no luck. I pull the nob and only get my headlights. Any help?
live2learn is offline
post #2 of 24 (permalink) Old Dec 23rd, 12, 06:26 PM
DjD
DjD's Avatar
Re: Electrical help.
Wayne I pulled your post out of the thread it was in because it made no sense where it was...
...Dennis
DjD is offline
post #3 of 24 (permalink) Old Dec 23rd, 12, 06:55 PM Thread Starter
Wayne
OK. I get it now. Thank you.
post #4 of 24 (permalink) Old Dec 23rd, 12, 08:09 PM
Chuck
I'm no expert but I have worked through a lot of wiring issues in the last month. I bought a wiring diagram from one of the internet Camaro parts dealers (sorry I don't remember the site) says its made by "classic car wiring", and it has been a huge help. It is a laminated card a little bigger than a legal pad. I had various problems, fuses, bulbs, bad wire splices etc. Hopefully yours is a simple problem and someone will come along with a fix for you, but I would look into a wiring diagram to have around. With the wiring diagram and a test light I was able to make sure I had power at the switch before replacing the switch. On my car the marker lights were on a different fuse than the headlights. My car is a 68 so the wiring may be different. Maybe you have a harness connector coming loose under the dash, or someone has done some bad splicing somewhere along the way.
Chuck617 is offline
post #5 of 24 (permalink) Old Dec 23rd, 12, 10:53 PM
69-Pace's Avatar
This should get you started.
You can join over at Jim's FirstGens site, he is a member here as well. http://firstgens.com site. Once a member download the full set from the downloads directory.
Name:	charging details.jpg
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 24 (permalink) Old Dec 24th, 12, 06:42 AM
Welcome, Wayne.
I will suggest the following, after using Brian's diagrams, I would say the dash crimp of the red wire(s) from the firewall connector, may be corroded, since you jumpered power.
Another place to look, is the horn relay buss bar. remove the wire terminations and wire braush everything, reassemble.
post #7 of 24 (permalink) Old Dec 24th, 12, 09:24 AM Thread Starter
Wayne
Ok Awesome! Thank you. Wire diagram is next.
I pulled power from hot lead on the headlight switch plug where it connects to the switch. I got 12.6 volts at the hot lead there, and then 12.6 volts at the tail lights after the jumper connection.
it seems to be a problem at the switch yet I have used three known working switches and still nothing.
Thanks for your replies.
post #8 of 24 (permalink) Old Dec 24th, 12, 12:12 PM
Brake, turn signals get their own individual power from the fuse panel.
Dash lights from h/lamp switch.
Turn signal indicators are tagged from front turn lights at firewall connector.
You might check instrument cluster ground in between the two pods.
It may have came loose.
post #9 of 24 (permalink) Old Dec 24th, 12, 12:55 PM
Nick
Have you check any bulbs to see if they are burned??
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #10 of 24 (permalink) Old Dec 24th, 12, 12:59 PM
Nick
do you have power at the fuse panel and have you check all the grounds
post #11 of 24 (permalink) Old Dec 24th, 12, 10:32 PM Thread Starter
Wayne
OK... Found some ground issues.
1) Does my dash cluster have to be hooked up for rear lights to operate?
I found the brake light fuse readings were surging from 11 volts then to 0.0 volts then to 10 volts off and on with no consistency. I hooked a battery charger up and the readings began to surge from 12 volts to 0 volts in rhythm.
Rear running lights randomly worked once again until I pressed the brakes. Never seen them again. NOTE: Blinkers work.
Re grounding will be finished tomorrow.
MERRY CHRISTMAS!!!!!!!
post #12 of 24 (permalink) Old Dec 24th, 12, 10:44 PM
Nick
check the small negative - wire at the battery see that it has a good ground to the fender.
Merry Christmas
post #13 of 24 (permalink) Old Dec 25th, 12, 08:28 AM
69-Pace's Avatar
Also check these items one by one....
https://www.camaros.net/techref/elect...or_support.htm
Main Splice, Junction block and Voltage Regulator are key bridges to the electrical system. Also look for damaged fusible links they will be discolored and crunchy. If I remember right 67-68 Voltage Regulators had their own ground straps to the shroud.
69-Pace is offline
post #14 of 24 (permalink) Old Dec 26th, 12, 06:43 PM Thread Starter
Wayne
Found some ground issues. Fixed them and everything started working again. Ran the car for a few minutes then they went out again. Brake dummy light started blinking.
All my grounds are solid. Anything?
post #15 of 24 (permalink) Old Dec 27th, 12, 08:04 AM
Blinking BRAKE light could be a misadjusted parking brake switch at the parking brake pedal. All the grounds you've done can be protected somewhat with a drop of oil on the ground connection and a star washer between the termial and body.
