Where do they Go? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 5th, 13, 06:24 AM Thread Starter
Bruce
Where do they Go?
Putting the wiring harness under dash in a 69 AC without guages or clock. Where does the yellow-black go and the light green-pink? Both are in the area of the heater control. Also what is the best way to plug in the dash lights once the dash is installed? I should have done it when just before installing! My favorite part of the build!
The Camaro Guy is offline
post #2 of 6 (permalink) Old Jan 5th, 13, 06:41 AM
69-Pace's Avatar
Re: Where do they Go?
Hummmm You say without gauges, but yellow/black is the low fuel warning light and pink green is a few things including console temp gauge Pictures might help isolate by plug configuration
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Jan 5th, 13, 07:10 AM
Rick
Legacy 69's Avatar
Yellow-black is that not the radio harness? Pink-green could possibly be the speaker wire if it is on the same connector.
Legacy 69
Legacy 69 is offline
post #4 of 6 (permalink) Old Jan 5th, 13, 08:42 AM Thread Starter
Bruce
I bought the car as a rolling chassis with all the parts in boxes, so alot of assuming is taking place. Having been born with a sb, 3 on the tree with AC, PB and no PS is interesting enough. The dash is in perfect shape as well as the wiring harness. I would guess it had an AM radio but the mysterious connections do not match the the back of a AM radio. The speaker has a green/black wire. To top it all off it was a frost green/frost green car! It is in the process of becoming a BB, 4 SPD, AC, console, Cortez Silver/black standard!
post #5 of 6 (permalink) Old Jan 5th, 13, 12:02 PM
69-Pace's Avatar
okay so pictures are needed I guess.
69-Pace is offline
post #6 of 6 (permalink) Old Jan 5th, 13, 12:25 PM
Guess
HwyStarJoe's Avatar
https://www.camaros.net/forums/showthread.php?t=206770
Here's the entire 1969 Camaro Assembly Manual in PDF. Scroll through to find all the wiring diagrams.
http://www.scribd.com/doc/32913817/69-Camaro-AIM
HwyStarJoe is offline
