Cigarette lighter - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 8th, 13, 06:25 PM Thread Starter
Jason
Cigarette lighter
Just purchased a new lighter for my '68 Camaro with the single copper pin. How do you wire such a thing?
jmet1977 is offline
post #2 of 8 (permalink) Old Jan 8th, 13, 06:35 PM
Vintage 68's Avatar
Wink Re: Cigarette lighter
It's wired to the unit via the Fuse Block 'Lighter/Cigar' output - which is 'Hot' constantly ...
The wire color is Red/Orange and it is a single wire.
The 90-deg. plug adapter for the rear connection pin is available from some auto parts stores in the "HELP" section or from the 'repoppers' as a pig-tail to wire it up.
Or - you can use a standard Packard 'barrel' connector ...
It is included in the Dash loom when using an original or replacement harness.
Believe it or not, I bought the last complete base and plug I needed at Summit Racing for @$4
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 8 (permalink) Old Jan 8th, 13, 09:23 PM Thread Starter
Jason
Thank you! I replaced all my wiring with a Painless 18 circuit Camaro/firebird harness. It has been easy so far but its the little stuff.
Thanks Again
Jason
jmet1977 is offline
post #4 of 8 (permalink) Old Jan 8th, 13, 09:57 PM
Sean
What John said, but to add to that be sure it has a good ground to the dash surface it mounts to, thats the other end of the circuit. Add a bunch of paint or rust on the dash and the lighter won't work.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 8 (permalink) Old Jan 8th, 13, 11:42 PM
Steps
Little of subject.....
the camaro has the lighter wired live, like the brakelights....and Im used to old classic cars for everyday transport....
The borrowed a friends modern car, put the garmin nuvi into the lighter and its not live...only live with key on
When did cars change?
1/2 by thinking about putting the lighter on the camaro onto a ign on only circuit.
Steptoe is offline
post #6 of 8 (permalink) Old Jan 9th, 13, 05:00 AM
69-Pace's Avatar
The past two jeeps I have had (95 & 06) all had one or two "power outlets" that were live all the time and the other two or three of them were only at ignition.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 8 (permalink) Old Jan 9th, 13, 05:13 AM
prostreet69camaro's Avatar
Make sure you have a good connection on the lighter connection. They produce alot of heat and the connection will melt or corrode over time.
You might take a pair of pliers and squash the connector a little bit to make it tighter.
prostreet69camaro is offline
post #8 of 8 (permalink) Old Jan 9th, 13, 09:53 AM
Vintage 68's Avatar
Talking Re: Cigarette lighter
Originally Posted by Steptoe View Post
Little off subject.....
the camaro has the lighter wired live ... borrowed a friends modern car, put the garmin nuvi into the lighter and its not live...only live with key on
Oh, about 10~15 years ago - where you been ( J/K )
My 2004 Trailblazer has two (2) 'Lighter outlets' right under radio - one is 'key-on' switched and the other is 'live' "hot" all the time, for accessories/chargers.
Thought it was weird when I got the vehicle, now I'm used to it ...
It also has three (3) others (for five (5) total - have no idea who fingered this option out ...) two (2) in the rear console for passenger use, and one more way in the back on side panel - all of these are "hot" all the time ...
BTW - not one of these had a 'Lighter' in it when I received the vehicle new from the dealer - just covers over them. Years later while I was digging through the little compartment in the side panel (to finally check if there was a Jack and Tire-iron before a trip ) I found a sealed bag with two 'lighters' and a funny round 'ashtray' thingy to put in one of the Cup Holders - for the Smokers I guess, but never would have looked there for it ...
Our new Traverse has all the lighter outlets "hot" all the time - and even the 110vac outlet is 'hot' with the Key-Off
They can produce a lot of heat at the connection if it is 'iffy' ...
I usually put some Conductive Paste (as used for home.Ind. wiring) on the connections for items like this to assure a great connection through their life.
Never have had a problem after starting this procedure.
"Squashing" most connectors causes the connection to have smaller localized contact points and will/can cause more trouble with 'heat' at the connection as just a poor connection.
1968 Convertible
Some trucks
