68 RS Front Turn Signal Lamps Wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 13th, 13, 01:56 PM Thread Starter
I am restoring my wiring harness and needed to repair the two wiring running to the each of the RS Turn Signal Lamps, it has a connector in the shape of a "T" for two wires. Does it matter how the other half of the connector is wired to the two wires from the harness? They are not the same color and I want to be sure one of these wires is not a ground? Is the ground provided when the lamp is bolted to the lower valance?
68rs327conv is offline
post #2 of 4 (permalink) Old Jan 13th, 13, 02:01 PM
69-Pace's Avatar
Re: 68 RS Front Turn Signal Lamps Wiring
I think it is the same 68 and 69 if I remember correct - one wire is parking lamp power - brown wire and the other is turn signal power - light and dark blue wires.
Ground is through the mounting to body.
Diagram attached.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Jan 13th, 13, 06:04 PM
jared
It's a dual filament bulb right ? Should be dim with the parklights on,and get brighter when the turn signal is turned on with it blinking .
jcfcamaro is offline
post #4 of 4 (permalink) Old Jan 13th, 13, 06:48 PM
69-Pace's Avatar
Jared it should have one filament in use for parking lights active and the other dark, then the other only lights when signal is on.
69-Pace is offline
