Installing front dash speaker - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 15th, 13, 08:01 PM Thread Starter
Larry
Just looking for help with installing front dash speaker. It's going in my 68 coupe with A/C. I have heard its an all day affair. Just looking for some info on where to start. What needs to come out or off to be able to get to the old speaker and bracket?
I'm not looking for people to try and talk me out of installing it or telling me a better place to put speakers. I have read the other posts and understand opinions vary. Is there any kind of literature with diagrams that could help? Thanks guys. Can't wait to get started. Below is the car I'm putting it in.
Jrs 68 is offline
post #2 of 7 (permalink) Old Jan 15th, 13, 08:45 PM
Todd
6781camaro's Avatar
Re: Installing front dash speaker
I would remove the radio and a/c controller to start, then assess how much room you have. That should be enough to get to it IMO. If your ductwork is still installed, that may need to be removed temporarily as well. (center vent feed duct)...
I just installed a new dash panel in my '68 and am just imagining what would need to be removed if I did that install.
Also-- try a youtube or google search using "1968 camaro dash speaker" as keywords in the search bar. You just may get something...
If you go to my '68 build thread, you can see what the upper cowl and dash panel areas look like without anything installed. That may help too...
Here's a good thread to read about placing speakers in the dash.... There's alot of good explanations in this...
http://www.pro-touring.com/showthrea...h-of-69-Camaro
Hope this helps.
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too),
'67 White 6 Cyl Coupe Building now (three!)
'68 Conv. V8 4-spd Builder, '68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
My build thread:
6781camaro is offline
post #3 of 7 (permalink) Old Jan 17th, 13, 03:32 PM Thread Starter
Larry
Thank you. That's more than I knew before so it should help.
Jrs 68 is offline
post #4 of 7 (permalink) Old Jan 28th, 13, 09:29 PM
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
Watching this thread. I have my NOS am/fm to install but want to replace the front speaker as well. The last time I heard it, there was more cracking than music.
Craig1969 is offline
post #5 of 7 (permalink) Old Jan 29th, 13, 04:45 AM
You might be able to remove the glovebox and get it from the side.
I have done it this way before.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #6 of 7 (permalink) Old Jan 29th, 13, 08:52 AM
It takes a lot of trial and error. I messed with the orig bracket until I had it just right. The orig speaker was turfed, as there are so much better ones on the market now than back then. I replaced it with a 4x8, I think it was?...and it sounded so much better than the skinny orig. I didn't remove the GB, and it was a cranky job!
capt
captcanuck68 is offline
post #7 of 7 (permalink) Old Jan 29th, 13, 09:35 AM
I have done this a few times, and with A/C, I don't think you can get there through the glove box. From my experience, you need to work from the bottom up. Remove the ash tray, remove the radio, unscrew the A/C controls, and let them drop down into he space created by removing the radio and ashtray. Unscrew the A/C vent, and you can work the duct pieces out the front of the dash. Once this is done, the speaker is pretty easy to remove.
Good time to replace the lights in the A/C controls if needed. Very hard to get to otherwise. I replaced mine with LED's so I hope to never have to change them again.
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
