Horn Assembly - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 5th, 13, 10:20 PM Thread Starter
Gary
Horn Assembly
Helping a friend on his '68 and he recently bought a new steering wheel (not a Grant) and it came with some parts for the horn. My question concerns the order of assembly on everything in between the turnsignal switch and the new wheel. And, the brass button on the T/S switch....should it depress? Is a fairly large spring installed next? Again, it is an aftermarket wheel that came without instructions. There is a plastic horn "contact assembly" that appears to be installed after the large spring, and, this part is sandwiched up against the new hub assembly. Is this correct? Does this part move as the wheel is being turned? Does it come in contact with the T/S switch? A small, lightweight spring and plunger is also in the kit. Any help would be appreciated!
Gary
Gar's67 is offline
post #2 of 4 (permalink) Old Feb 15th, 13, 08:46 PM Thread Starter
Gary
Re: Horn Assembly
A little help from the pro's.....is the correct order of assembly on a '68, non-tilt column, after the turn signal switch: Cancelling cam, big spring, and the hub included with new wheel? Thanks...working on it tomorrow.
Gary
Gar's67 is offline
post #3 of 4 (permalink) Old Feb 17th, 13, 05:53 AM
Re: Horn Assembly
Gary, here is a pic of a 69. 68's are a little different as they don't have the ignition in the column, but this may help with order of assembly. I think you are looking for #1-6
69 RS/SS X22 51-51 Dusk Blue coupe in resto......still.
69 X11 355 ci M22 3:73 12 bolt...current driver
Spooky is offline
post #4 of 4 (permalink) Old Feb 24th, 13, 09:36 AM Thread Starter
Gary
Re: Horn Assembly
thanks for the reply Spooky! I ended up using the original canceling cam which is recessed to fit the big spring, and then the new hub that came with the wheel (all in that order). A new horn relay was also needed ($19 Amazon Prime) and everything works great. Again, thank you!
Gary
Gar's67 is offline
