Distributer Location? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 24th, 13, 06:43 AM Thread Starter
Bruce
GM HEI distributer, 454. The timing mark is on dead center with the #1 piston at the top. Where should the rotor be pointing? I always thought it should be pointing to the #1 piston. While reading the service manual it showed it pointing to #2, 45 degree to the right from the front center of the engine. Which is correct?
The Camaro Guy is offline
post #2 of 5 (permalink) Old Feb 24th, 13, 07:05 AM
Re: Distributer Location?
Most are pointing #1 cylinder.
You can place the firing order in any one of eight starting positions as you chose.
Does the picture appear to be backwards?
post #3 of 5 (permalink) Old Feb 24th, 13, 07:15 AM
Michael Gekko
Depends on which stroke #1 is on. The timing mark on the damper will indicate the #1 piston being at TDC twice on a 4 stroke engine. Once at the beginning of the firing stroke and once at the beginning of the intake stroke.
Eleanor's Nemesis is offline
post #4 of 5 (permalink) Old Feb 24th, 13, 07:22 AM
Jeff
yellow69RS's Avatar
Originally Posted by Everett#2390;1782852[B
]Most are pointing #1 cylinder[/B].
I understand what both of these terms mean but others may not. I say it should be pointed at the number one plug wire, or number 1 on the cap.
Jeff
yellow69RS is offline
post #5 of 5 (permalink) Old Feb 24th, 13, 09:00 AM
Vega$69's Avatar
Jeff
On TDC of the compression stroke
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
