67 camaro hide a way lites - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 1st, 13, 09:49 AM Thread Starter
my hideaway lites work fine but i find i am drawing from the battery when everything is shut off, where do i start looking? Does the diode have anything to do with it?? Any help would be greatlly appr.
railer3 is offline
post #2 of 4 (permalink) Old Mar 2nd, 13, 08:09 PM
Rocky
Re: 67 camaro hide a way lites
I'm no expert but had a similar issue with my 67. So I started at the fuse block removing one fuse at a time and testing each until I found which circuit was the culprit. At least you narrow it down. My ended up being a bad ground on the horn.
Hope this helps some what.
What's a mid life crisis
67 SS
Hothead is offline
post #3 of 4 (permalink) Old Mar 5th, 13, 10:06 PM Thread Starter
thanks
railer3 is offline
post #4 of 4 (permalink) Old Mar 6th, 13, 04:25 AM
The best troubleshooting method is remaove a battery cable and insert a light.
Glowing, heavy current draw.
Dim glow, aftermarket radio or other device drawing 'keep alive' current due to clock function, presets, etc.
No glow, good.
Another dim glow could be a leaky alternator diode, might disconnect the red wire on BATT stud.
