Early 1969 voltage regulator mounting - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 2nd, 13, 06:42 PM Thread Starter
Does anyone have any pictures of a voltage regulator on an early 1969 build with the well nuts and ground wire. I am trying to determine the correct mounting for my September 1968 built Z28. Do all voltage regulators have the radio capacitor mounted to them as well? Thanks for the help.
Scott69Z is offline
post #2 of 4 (permalink) Old Mar 3rd, 13, 07:17 AM
Re: Early 1969 voltage regulator mounting
No wellnuts for '69, bolted directly to rad support.
U69 is the noise suppression RPO and included , caps at the blower (feedthru cap), VR, ground straps from engine to firewall, body to subframe, and wheel bearing dust cap inserts.
post #3 of 4 (permalink) Old Mar 3rd, 13, 07:27 AM
duU69 is the noise suppression RPO and included , caps at the blower (feedthru cap), VR, bearing ground straps from engine to firewall, body to subframe, and wheelst cap inserts.
I thought it was a mid-year change?
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #4 of 4 (permalink) Old Mar 3rd, 13, 08:35 AM
click's Avatar
My Oct 68 built 69 Camaro had direct bolt to rad support and no groundstrap, the mounting bolts provided ground but be sure the lock washer or star washer grips thru the paint to make that ground happen
click is offline
