No turning signals and crazy break lights!!! - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 3rd, 13, 07:26 PM Thread Starter
Brad
I just rewired my entire 69 Camaro. Once I got all the bulbs back in I had some crazy thjings happen. Now I have no turning signals at all, before I installed bulbs I did. I checked all fuses and there still good. My break lights work but when I hit the break my dash lights and marker lihgts all come on. Im completly frustrated and cant figure out what could be causing this. Im using an american auto wire kit as well. Any suggestions are much appreciated.
69 Camaro SS Burnt Orange 355 SB 4 speed.
67 Camaro RS LS Project
Yates is offline
post #2 of 5 (permalink) Old Mar 3rd, 13, 07:30 PM
Vega$69's Avatar
Re: No turning signals and crazy break lights!!!
Check Tail light grounds in trunk just above filler neck
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 5 (permalink) Old Mar 3rd, 13, 07:43 PM Thread Starter
Brad
Yes I have them all attached at same area . would this make any difference? Break lights are working good. I dont understand how my break lights got tied in with my dash lights??
Yates is offline
post #4 of 5 (permalink) Old Mar 4th, 13, 12:27 AM
Steps
When one has bad grounds there are weird feed backs in the system which causes weid stuff to happen
Steptoe is offline
post #5 of 5 (permalink) Old Mar 4th, 13, 04:45 AM
Kevin
KevinW's Avatar
I had a similar problem. Would bench test and ohm out all bulbs in the taillight harness and they worked fine. But when installed, the ground backfed into dash lights. Unwrapped and replaced ground wire, same issue. Had to replace taillight harness with a spare. There must have been an internal issue in the ground path that ohmed out, but could not take the amps. I never did figure it out.
Kevin
KevinW is offline
