Park lights not on with headlights - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 5th, 13, 10:19 PM Thread Starter
Wesley
I have a 67 Camaro. Was wondering if the park lights in the font grille are supposed to come with the headlights? They come on when the headlight switch is pulled halfway out, but go off hen I pull the switch all the way out.
67 SS 454 4 speed
Wpeschel is offline
post #2 of 7 (permalink) Old Mar 6th, 13, 03:20 AM
Jason
Re: Park lights not on with headlights
On 67's the park lights are OFF when the headlights are on.
steery is offline
post #3 of 7 (permalink) Old Mar 6th, 13, 03:22 AM
Jason
If you would like the park lights to be on when the head lights are on you can pull the purple wire (park lights) from the back of the headlight switch and join it to the brown wire (tail light)
steery is offline
post #4 of 7 (permalink) Old Mar 6th, 13, 06:36 AM
Michael
Actually, you just have to reassign (pull) one wire from the light switch to another position (plug).
mahunt is offline
post #5 of 7 (permalink) Old Mar 6th, 13, 07:50 AM Thread Starter
Wesley
Could you explain this? I'd sure appreciate it. Thanks for the help.
67 SS 454 4 speed
Wpeschel is offline
post #6 of 7 (permalink) Old Mar 12th, 13, 09:30 PM Thread Starter
Wesley
Bump for a better explanation. Thanks.
67 SS 454 4 speed
Wpeschel is offline
post #7 of 7 (permalink) Old Mar 13th, 13, 06:35 AM
Michael
I'd have to take my dash apart to spot the exact wire to pull (sorry the car is in use), but if yours is apart you'll notice that on the light switch there is an unused slot on the harness connector.
Separate the light harness connector from the light switch and you'll notice that the empty slot on the connector involves an unused connection tab on the light switch. This is the slot where you will plug in the wire that you pull.
I can't remember which wire or the color of the wire that gets pulled, but it's the one that lights the front parking lights. Obviously, it's one of the thinner wires and pick a color that somewhat matches the parking light's wiring.
When you find a candidate, depress the tab keeper on the wire terminal, eject the wire from the harness connector. Reform the tab keeper on the wire terminal so it will catch and hold in the harness connector. Plug it in the new slot. Put everything back together and give the switch a pull.
mahunt is offline
