Drivers rear blinker issue. - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 7th, 13, 11:23 AM Thread Starter
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
68 SS/RS, all lights work until the engine is started. Everything works except the drivers REAR blinker, both bulbs, and brake lights on drivers side, both bulbs. All other lights, blinkers, flashers work. I have however noticed the dash lights dancing a little when the car is idling and does ok above idle.
Any ideas what the gremlin is?
Craig
Craig1969 is offline
post #2 of 3 (permalink) Old Mar 7th, 13, 03:23 PM
Re: Drivers rear blinker issue.
Turn signals use the same filament as brake lights, and both power goes through the turn signal switch and since both brake lights work, grounds are good.
Front blinkers work, as they each go through their own circuit through the t/sig sw.
Rears do also,. So you might check for power at the steering column connector for rear blinker power.
No power, bad t/sig sw or poor connection, or poor connection at the body connector in the drvr kick panel.
post #3 of 3 (permalink) Old Mar 8th, 13, 05:55 AM Thread Starter
Craig
Craig1969's Avatar
Thanks.... This is my "mission" for today!
