67 rs headlights - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 9th, 13, 07:10 PM Thread Starter
67 rs headlights
Sorry to bring topic up again, but I'm down to the final issue with the headlight doors. When I pull the headlight switch, the driver side headlight door opens up, but the pass door does not. If I lightly tap it, it opens right up. When I turn them off both doors close just fine. I've been thru relay board, checked all grounds, checked to make sure both doors are in contact with stops. No issues with any of these's items. Any suggestions on what else to check. I've been killing my self on this issue for two weeks now.
thanks
RSSS69 is offline
post #2 of 2 (permalink) Old Mar 9th, 13, 07:21 PM
jared
Re: 67 rs headlights
Maybe its a bad limit switch, You say if you tap on it it opens. Bad connection on the wires
jcfcamaro is offline
