1967 Camaro brake lights not working - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 10th, 13, 01:41 PM Thread Starter
Wesley
My 67 camaro brake lights are not working. My tail lights, blinkers, and flashers work except for the brake lights. The bulbs are good and the brake switch works, but there is not 12 volts to either side of the switch. All of the fuses are good. What else should I check? I'm planning on trying a new blinker switch, I've read that it could be bad.
67 SS 454 4 speed
Wpeschel is offline
post #2 of 6 (permalink) Old Mar 10th, 13, 02:36 PM
jared
Re: 1967 Camaro brake lights not working
you do have the 1157 bulbs right ?
jcfcamaro is offline
post #3 of 6 (permalink) Old Mar 10th, 13, 05:38 PM Thread Starter
Wesley
Yes. They used to work before the car sat in stirage for several years.
67 SS 454 4 speed
Wpeschel is offline
post #4 of 6 (permalink) Old Mar 10th, 13, 06:01 PM
jared
Not sure which brake light switch wire is the hot coming in, but i'd trace them. I do know that behind the drivers kick panel is the plug and harness that runs all the wires back to the tail lights,so if one of the brake light switch wires runs over to the side of the kick panel trace the other switch wire to find the hot side>. you might make sure your column wiring plug is tight together .
post #5 of 6 (permalink) Old Mar 10th, 13, 06:36 PM
Stop lights get their power from fuse panel.
Then to brake light switch, then to column through turn signal switch.
post #6 of 6 (permalink) Old Mar 12th, 13, 08:44 PM Thread Starter
Wesley
Ok after doing some more testing I have found out that my brake switch is not working correctly, sometimes it works, and sometimes it does not. After unplugging and plugging back in the big plug to the turn signal switch, I now have power to the orange wire at the brake pedal switch. A bypassed the brake switch and the brake lights now work, but they will not work while a turn signal is on. What else should I look at? I have a new turn signal switch and brake switch I will install tomorrow.
67 SS 454 4 speed
Wpeschel is offline
