Replacing amp gauge in 69 - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 10th, 13, 03:53 PM Thread Starter
I am getting ready to replace my amp gauge in the console of my 69 Z28
looks like I need to unplug the wire connector in the console and then remove the whole console?
Any suggestions on how to remove the old gauge
would be a big help.
Thanks in advance
oldkid is offline
post #2 of 9 (permalink) Old Mar 10th, 13, 04:55 PM
Banned
Chet
Re: Replacing amp gauge in 69
If this is a factory gage cluster, you don't have to remove the whole console. You undo the screws that hold the gage cover onto the console and access the individual gages. Check out the A.I.M. for the 69.
154567 is offline
post #3 of 9 (permalink) Old Mar 10th, 13, 05:41 PM
STEVE
Take off your shifter plate, and there are 2 screws facing up just under the fwd edge of the opening.
After this removing the screws you should be able to gently pull the gauges straight back ( 'bout 1/2" ), and lift the gauge assembly out.
Thanks in advance
fast_in_muskoka is offline
post #4 of 9 (permalink) Old Mar 10th, 13, 11:09 PM
STEVE
CRD is correct with his post, disregard my destructions . . .
post #5 of 9 (permalink) Old Mar 11th, 13, 04:56 AM
Tim
Just be really careful not to damage the oil line....
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #6 of 9 (permalink) Old Mar 11th, 13, 03:34 PM Thread Starter
Ok, I looked on every page of the AMI and there is nothing showing a picture of the gauges installed in the console.
I am trying to remove the amp gauge which is in the back section of the gauge cluster in the console.
I removed the 3 screws in the top of the instrument housing but the gauge will not move.
I guess I need to disconect the wire plug and lift up the console to get under the amp gauge to disconect it?
oldkid is offline
post #7 of 9 (permalink) Old Mar 31st, 13, 08:22 PM
350camaross's Avatar
I attempted this today on my 69 Camaro.I had to replace the Amp guage also.The first set of guages(fuel/temp)in the center of the bracket there is a small flathead screw which holds it down,for the Amp/temp gauge bracket there are 2 -3/8' bolt head screws in each front,L&R corner.I had to use a mirror to actually see them.The left corner screw also has the ground wire attached to it,which is also screwed into the center of the guage bracket.
Unfortunately for me after installation and putting everything back together,the new amp guage still doesn't show a reading(needle is at "0"),and after putting more gas in the fuel tank,come to find out my fuel gauge is stuck on it's previous reading,so now that's screwed up.Been thinking about a new autometer gauage set,and getting rid of the ancient gauges.
350camaross is offline
post #8 of 9 (permalink) Old Apr 1st, 13, 04:11 AM
Console attachment: See #5, Screw in each corner.
Ammeter has a wire on the horn relay buss bar and battery junction block.
Disconnect them and see if ohmmeter can read the ammeter. Ammeter should move to one side with ohmmeter leads attached.
Everett#2390 is online now
post #9 of 9 (permalink) Old Apr 2nd, 13, 06:07 AM
What are the 4 steps indicated on the diagram for removing wires for?Is this a fix for the ammeter guage to work correctly/I don't understand what this document is for.Can ya help me out?
