Xenon hid kits, do I need the ballasts? - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 22nd, 13, 01:36 AM Thread Starter
Anthony
Hey guys, I am going electric hideaway lights on my 69 camaro from Matt Klemp. I have also elected to go with hid lights, it has ballasts and 7 inch bulbs, How does this work? We plugged in the bulb to the stock harness an they lit up pretty bright. The guy installing the kit wasnt really sure. This is the kit I have http://www.ebay.com/itm/8000K-Slim-X...73f14f&vxp=mtr . Has anyobe used these or know how this works? Thanks again guys.
69 Camaro coupe project link
69GreyGhost is offline
post #2 of 14 (permalink) Old Mar 22nd, 13, 05:05 AM
Re: Xenon hid kits, do I need the ballasts?
Some info:
http://www.ballastdesign.com/overview.shtml
Yes, you do. It keeps the lights from flickering and keeps them lit at a constant brillance when power flucuates, as in turn signal selection.
This has alittle more info:
powerelectronics.com/mag/610PET22.pdf
post #3 of 14 (permalink) Old Mar 22nd, 13, 06:04 AM Thread Starter
Anthony
Originally Posted by Everett#2390 View Post
Some info:
Those articles were helpful but if you look at the kit I put in the link we dont understand how the ballast and wires hook up to the bulb without splicing wires.The ballast and wires already come connected to a new bulb but one that isnt compatable with the 7 inch bulb. A diagram or pictures of what other members have done would be extremely helpful.Can anyone help with that?
post #4 of 14 (permalink) Old Mar 22nd, 13, 06:34 AM
Jake
697ibew's Avatar
You should contact the vendor/manufacturer of the item on your question regarding the splicing. Without looking at it myself, I would assume that you'll need to cut and splice wires. I personally would take it a step further and use a relay to energize the ballasts. I would use the factory low beam wire to feed the coil of the relay and run a FUSED dedicated 12 volt feed through the normally open set of contacts on the relay to the ballasts. HID lamps use a high initial amperage when first fired up and then the amperage will lower as the lamp brightens. This initial in-rush of current may be too much for older factory wiring. The only way I think that you'd be able to hook up the lights without splicing the factory wiring, would be if you can find an adapter/pigtail that would "plug" into your factory headlamp socket and have a 12 volt positive and negative wire on the other side of the adapter. Good luck. Jake
697ibew is offline
post #5 of 14 (permalink) Old Mar 22nd, 13, 07:12 AM
Good point, Jake. Yes, put each headlamp on its own relay as power is readily available close by, battery junction block for the pass side and horn relay for the drvr side.
Also, if you are running an external reg'd alt, 10DN, OE design, you may need to go to an internal reg'd alt, 12SI, of more amperage. Remember the flickering of lights?
post #6 of 14 (permalink) Old Mar 22nd, 13, 07:28 AM
Kevin
SixtyAte's Avatar
The kit comes with everything you need! Plug and play....
Pug the light harness into ballast, plug the light in and you are done.
My son installed these in his car in 5 min and has been using them about 3 months now without problems.
Kev
SixtyAte is offline
post #7 of 14 (permalink) Old Mar 22nd, 13, 08:03 AM
Jake
697ibew's Avatar
You could use one relay for both lamps. If you would like...
697ibew is offline
post #8 of 14 (permalink) Old Mar 22nd, 13, 08:21 AM Thread Starter
Anthony
Kev
What about the bulb already attached to the harness? It came with some sort of adaptor for the back of the 7 inch bulbs, but I'm not 100% sure if that is how it works. The issue is we see the ballast and we see the harness has a bulb already attached to it. Do we keep the old bulb or splice wires? That's the problem. It was late so maybe we didnt look at it properly. I will go to the shop today and try to tell the guy what you guys have told me. But the extra bulb connected to the harness what about it? That's what really throws us off. It just doesn't look like it works all together.
post #9 of 14 (permalink) Old Mar 22nd, 13, 10:18 AM
I would still use a relay for each light, less line loss of power.
If you are talking about this bulb, it plugs into the reflector shown.
post #10 of 14 (permalink) Old Mar 22nd, 13, 10:38 AM Thread Starter
Anthony
What reflector? If I use the 7 inch houseing will both plugs be plugged into the ballast and the harness? Can someone post a pic of where the 7inch housing goes to the wiring harness?
post #11 of 14 (permalink) Old Mar 22nd, 13, 11:16 AM
Look at the kit in the ebay link.
The reflector is hollow, no bulb plugged into it.
post #12 of 14 (permalink) Old Mar 22nd, 13, 11:23 AM Thread Starter
Anthony
I see what you guys are talking about, mines isn't hollow. I plugged the 7 inch light directly to my stock wiring harness and it lit up. That's why we are so confused. The kit I have looks incomparable with its parts. The link was just of the same kit I don't think it's from the same company. It just looks very much the same.
post #13 of 14 (permalink) Old Mar 22nd, 13, 05:25 PM
Relays for headlights = great idea. Use 2 relays - one for high beam and one for low beam. Tap into harness on driver's side by core support. As said - orig high beam (light green) & low beam wires ( tan) to trigger relay coils, relays provide the switching, and get fused power from horn relay busbar. Takes all but of a few miliamps of load off of the headlight switch and related wiring.
BPOS is offline
post #14 of 14 (permalink) Old Mar 24th, 13, 12:05 AM Thread Starter
Anthony
Ok guys, I feel kinda remedial. We looked at it and realized the 7inch light was just a housing that comes out and the hid kit plugs into that. We thought the bulb was fixed and didnt know it was just a way to use the kit. Thanks guys for all the help. I will post pics when the conversion is 100% complete.
