Basic electrical question - Team Camaro Tech
post #1 of 23 (permalink) Old Mar 23rd, 13, 06:08 PM Thread Starter
Ted
If you had all electrical components wired up correctly and everything grounded well. Would you see a spark when taking the negative batt cable on or off? If you did. Then does that mean you have a positve wire somewhere touching ground?
tgifford5 is offline
post #2 of 23 (permalink) Old Mar 23rd, 13, 06:10 PM
Re: Basic electrical question
Somethings drawing power.
68 Camaro~LSx ~all motor
post #3 of 23 (permalink) Old Mar 23rd, 13, 06:13 PM
Sean
Not a huge arc but probably a spark, somewhere in the system there is a load, could be anything, stereo etc., and when you brush the cable across the post it will draw an arc.
If it's a huge arc and everything is turned off, I would be nervous. It's not a positive cable going to ground though, because if it was you would have melted wire shortly.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 23 (permalink) Old Mar 23rd, 13, 06:21 PM Thread Starter
Ted
I dont have melted wires. I need to find the source of this arc issue. I think it is the cause of my gremlins. I guess unplug everything. Then slowly add one item in at a time.
post #5 of 23 (permalink) Old Mar 23rd, 13, 06:27 PM
Sean
Are you having a battery drain issue?
Sean
68rs406 is offline
post #6 of 23 (permalink) Old Mar 23rd, 13, 06:54 PM Thread Starter
Ted
Well I dont think so. But what would be your reasoning on batt drain? I have had the neg cable disconnected over the winter. When running my gauge reads 14v. I would suppose if I left it all hooked up it would eventually drain. But I dont know what that duration time would be. I have a couple elec posts going presently to try and figure out whats up.
post #7 of 23 (permalink) Old Mar 23rd, 13, 07:10 PM
Sean
Not necessarily a problem, there are things that always have some draw, just not much and not enough to kill the battery.
It can be any number of small things and never be a problem. If it doesn't drain your battery (while hooked up of course..) over a period of time, weeks, months even, you don't have an issue.
It could be as simple as the constant hot to your stereo to keep your clock accurate and it will draw a small arc when you pul the cable away.
Is there any concern other than you noticed an arc?
Sean
68rs406 is offline
post #8 of 23 (permalink) Old Mar 23rd, 13, 07:56 PM Thread Starter
Ted
Well if you see my other posts going right now. Those are my issues. Dul electric fans keep running after the car is turned off. And my headlights flicker. But only when the car is running. Not when the motor is off.
post #9 of 23 (permalink) Old Mar 23rd, 13, 08:22 PM
Robert
You can pull one fuse at a time to see if the arc goes away, that might tell you something.
Robert
TC member #18
rojo is offline
post #10 of 23 (permalink) Old Mar 23rd, 13, 08:57 PM
Sean
Have not seen the posts. Have a link?
I'm not a DC wiring expert but I have done a bunch of wiring on 2-3 race cars and I make a living wiring buildings....
I had a bunch of odd issues when I first bought my car and chased them down for a couple of weeks, it almost always came back to one thing, a bad rusty connection at a ground or fuse terminal.
Your fan issue sounds like you are not using a relay or not properly using a relay, there is no reason for them to run if the switch is off (how do they switch?).
I'll see if I can find the thraeds and maybe I can give some input there, there are a few guys that are pretty sharp with electrical systems on here. It can't be that bad.
Sean
68rs406 is offline
post #11 of 23 (permalink) Old Mar 23rd, 13, 08:59 PM
Sean
This is always a good way to narrow it down for sure. It will depend on how "customized" your electrical sytem is...
Sean
68rs406 is offline
post #12 of 23 (permalink) Old Mar 24th, 13, 08:28 AM
Gordon
gordr's Avatar
Mine negative cable does a little spark when taking off or putting on. It's because of the clock in my console gauges. I can leave my car for 2 or 3 months and the battery is still right up there in charge and fires the big block right up, so I have no concerns about my little spark.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #13 of 23 (permalink) Old Mar 24th, 13, 08:59 AM
click's Avatar
Get a cheap 12v light stick at auto parts store, disconnect NEG cable from battery, clip alligator clip onto the cable bolt and 'stick' the sharp point into the battery terminal (have someone hold it in there tight and he can also hollar if the light goes off or on) ...guessing the light 'lights up' at this point. Now pull fuses one at a time, till you see the stick light go 'off'...now you have the circuit where the draw is. Now trouble shoot that circuit works great
click is offline
post #14 of 23 (permalink) Old Mar 24th, 13, 04:25 PM Thread Starter
Ted
Thank you Click. I will try that. Now to find a willing partner.
post #15 of 23 (permalink) Old Mar 24th, 13, 04:55 PM
Paul B
"Well if you see my other posts going right now. Those are my issues. Dul electric fans keep running after the car is turned off. And my headlights flicker. But only when the car is running. Not when the motor is off."
The fans depend on what power source you connected to. If you connected to a switched terminal on the fuse box, one that has no power with the key in the off position than the fans should stop running right away. If you have them wired to something with 12V regardless of the position of the ignition switch, then the fans will run until the sender reads the temp where they turn off.
paulsstuff is offline
