Battery not Charging - Team Camaro Tech
post #1 of 30 (permalink) Old Mar 24th, 13, 03:13 PM Thread Starter
My 1967 Camaro is a standard console shift AT car with warning lights converted to console gauge and tach. Since the conversion my battery is not being charged.
My alternator tested out very good, the Voltage regulater is new and the battery is new.
When the car is running i get 12.5v, how can i pin point the problem if its wiring. Or where would be a good place to start.
I need some help!
ra11eysport is offline
post #2 of 30 (permalink) Old Mar 24th, 13, 03:20 PM
jared
Re: Battery not Charging
With your rs headlight door motor being shorted out and making the relay pop,you might try re-testing since you unpluged the motor.
jcfcamaro is offline
post #3 of 30 (permalink) Old Mar 24th, 13, 05:00 PM Thread Starter
I did that hoping it was it!
post #4 of 30 (permalink) Old Mar 24th, 13, 05:12 PM
jared
Is it the stock style ( external ) or has it been updated to a internal regulated alt
post #5 of 30 (permalink) Old Mar 24th, 13, 06:07 PM
I would start at the alt BATT stud and measure from the stud to ground.
If no volts, does it have field voltage?
No field voltage, does F terminal on VR have field voltage?
If F terminal does not have voltage, bad VR.
Trace the red wire from alt BATT Stud to positive battery post.
Every connection point should have alt voltage, aka, horn relay buss bar, battery junction block.
Also, negative battery cable at both ends should be a clean connection.
post #6 of 30 (permalink) Old Mar 24th, 13, 07:44 PM
Steiner
If you did anything funky with the old warning light wiring at the "gen" light in the dash when you converted to gauges then you could've lost the sense line for the voltage regulator. I think it's the brown wire at the voltage regulator and should have system voltage on it with the car running or key turned on. It comes from either on side of the "gen" light or a parallel reisistor wire (in case gen light burns out). The console gauge cars only have the resistor wire running from key switch. Not positive as I only run internal regulators.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 30 (permalink) Old Mar 25th, 13, 01:41 PM
George
Gbauer's Avatar
That is my guess from what he said he did so far.
...and I, too, had enough of the external VR stuff and just went 1 wire...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #8 of 30 (permalink) Old Mar 25th, 13, 02:46 PM
Chuck
I agree also on installation of a 1 wire alternator. After rebuilding my harness 2x when a regulator went bad and melted wiring....well lets just say there are better, newer options. Plus you get that ugly block off your core support. No more need for the power distribution post if while you are at it, you get creative with your new wiring As to how you wired it up, David Pozzi has a good article on why it will not work. Read the very last few lines.
http://www.chevelles.com/techref/ftecref14.html
Another page that may help you:
http://www.pozziracing.com/camaro_electrical.htm
You cannot bypass the bulb in the bezel for your speedo and tach if you are using an old style alternator. I say that.... you could just wire in a small resistor (ohm out the bulb, though i have never tried this) to simulate the bulb, but you will definitely need resistance in that circuit for it to charge properly.
67 rs/ss
381 sbc 11:1 AFR Heads Holley 950 EFI
DSE Quadralink
"From what I have replaced in pursuit of more, I could have built another one."
cfry is offline
post #9 of 30 (permalink) Old Mar 25th, 13, 02:47 PM Thread Starter
Thanks guys, I will see if I did something wrong with the gen light wire.
post #10 of 30 (permalink) Old Mar 26th, 13, 12:13 PM Thread Starter
The instructions from the console gauge conversion said to cut off Gen wire tape it off cause it will not be used. That's exactly what I did. Everything has voltage from the battery, through the alt and vr.
post #11 of 30 (permalink) Old Mar 26th, 13, 04:19 PM
George
Gbauer's Avatar
Hate to say it but there's your problem right' thar!
try reconnecting the gen wire if there's a light in your new gauges. The external voltage regulator needs the resistance to work properly.
That said I've heard that not having the bulb may burn out your VR so don't be surprised if that does not fix the problem.
if your VR is shot I found that the prices on them has gone up. Many people will quote $10 as the going price but reality is closer to 25-35. At that point you're halfway to just getting a modern alternator with an internal VR.
Rather than fight the whole system I replaced my alternator and regulator with this. http://item.mobileweb.ebay.com/viewi...d=350690663384
I opted for the 1wire install. I also added a ground wire. Holds a very steady 13.7 Volts at all rpm's.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #12 of 30 (permalink) Old Mar 26th, 13, 04:40 PM Thread Starter
I didn't actually cut it, but rather pulled it out of the instrument connector. So I should put the gen wire back in the 11 spot. I will do that and report back. Thanks a lot.
post #13 of 30 (permalink) Old Mar 26th, 13, 06:29 PM Thread Starter
Didn't work!
post #14 of 30 (permalink) Old Mar 26th, 13, 07:32 PM
Paul
I remember when I worked as a mechanic spending a lot of time working on a car that wasn't charging only to find out the bulb in the idiot light was burned out.
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
post #15 of 30 (permalink) Old Mar 26th, 13, 07:38 PM Thread Starter
I put the gen wire back and inserted the bulb. I will double check and make sure the bulbs to burnt. I'm thinking about trying out the 1 wire alternator just to maybe eliminate the vr and alt as the problem.
